Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Thread: 76 Jeep cherokee cheif, $500
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    Alright i bought a jeep for the quadra-trac and am selling the rest whole. I dont want to part it out.
    1976 cherokee cheif 2 door
    360 v-8 with 4 barrel edelbrock carb, guy i bought it from said it ran pretty good but might need the carb rebuilt, unknown mileage.
    2- th400 trans one that came out of the truck that the case is trashed because of a blown front d-shaft(evidently a common problem in wagoneer/cherokees of this vintage. The other trans supposedly came out of a 79 wagoneer, but doesnt have the same bell housing pattern as the one that came from the truck
    4 -stock aluminium 5 slot 6 lug 15inch wheels with stock rear hub caps
    suspension- front sprungover with stock springs, and a 1 block under the springs. Caster has set at 5 degree's when the perches were welded on. Rear 6 in skyjacker block kit. Steering is stock steering flipped over the knuckles(may be stock) with a 6 inch skyjacker drop pitman arm. The brake lines have been extended.
    Dana 44's f/r previous owner said that it had 3.54 gears.
    Driveshafts i have both f/r driveshafts the front needs one of the u-joints in the double cardan joint. i have a spare front d-shaft that will go with it.
    Motor has a york, and will come with a battery, also has cruise control but it is not hooked up. Motor was running when tranny was pulled.
    Body has been completey bedlined with some thing like dupli-color or herculiner. Body has maybe 4 spots with bondo, but they hardly noticable. This truck has some of the best sheetmetal as far as rust that i have seen on jeeps of this age that are in the sub 1k dollar range. Interior is stock, but seats need recovering. Floor pans and floor are solid and have been bedlined as well. factory roof rack still installed and in good shape. The back windows still open. All windows in the truck are manual and work. The back tailgate is missing the glass but i will throw in the one from my wagoneer. The front grille is also in great shape and has a good shine to it. Tailgate is a little hard to close.
    The previous owner used a boat gas tank behind the driver seat to fuel the truck but i will throw in a stock tank that will work in this truck as well.
    The back c-channel crossmember that runs under the tailgate of the truck has been removed, because of getting bent when the truck was pulled out of the mud when the tranny broke before i bought it.
    No title- $500
    call me at 713 670 4535 if interested because i want this thing gone fast and i wont be checking the boards alot this weekend.
    Extensive pics
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    Wylie, Tejas
    chief, chief
    I'm sorry, I couldn't resist.
    Boats and hoes
    Oct 2004
    Headed back to the Big D
    Hot pocket but this
    Registered User
    May 2003
    Htown
    Quote Originally Posted by BMFScout View Post
    chief, chief
    [Clyde Crouch] Thanks, Chief [/Clyde Crouch)
    So you loose, I win!
    Rawr TexTJ209's Avatar
    Sep 2004
    Waco, Tx
    It isn't even a Chief though, just a regular Cherokee.
    Edit: And just in case you do end up parting it...I want the Grille, Manual rear window setup, and the Chief emblems you mentioned.
    '73 J2000 Thriftside Gladiator, 258/T14/D20
    '81 CJ7 Laredo, 258/T176/D300
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    i want this thing to go to a good home $425 tamor price can deliver within an hour or so of crosby for cost of gas.
    call me dont post if interested, as i most likely will not be on the boards again till next monday.
    Jan 2006
    DAAAnngerrr Zone!
    Quote Originally Posted by AggieTJ2007 View Post
    Hot pocket buy this
    bump!
    'Cause if she don't,
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    $400
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    $350 for tamor members this will be the last price reduce, i really dont want to cut this truck up but i will
    lowballing someone
    Feb 2005
    Houstonish
    if you do i would like the front axle shafts, or maybe the whole thing and maybe the front springs, and maybe the front driveshaft
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    i wont be selling the axle shafts from the front. if you want that much stuff it would be cheaper for you to come get the whole thing and sell the motor and body in all sincerity.
    lowballing someone
    Feb 2005
    Houstonish
    true, but i'm broke and brian won't let me borrow any money to buy any more 4x4's. and if i did buy it i would slap a 400 and d20 in it and make it a ranch truck. you don't want to trade most of a chevy 60 do you
    Jun 2005
    Krazy Krosby
    Good story. Thanks for letting us know your current financial situation and family situation. Plus plans for a truck you don't have.
    Lets stay on topic, just trying to help Frick sell this thing. Did Frick mention it has a "If you can read this roll me over" license plate holder? This obviously doubles the value.
    -Karl
    1965 Chevelle
    1975 Corvette
  15. #15
    Jan 2006
    DAAAnngerrr Zone!
    Mr. Pot, meet Mr. Kettle....
