Like it says:
HPD30 non Vacuum disconnect
Out of a cherokee porfavor
Like it says:
SHUT UP AND WHEEL
? the are not that much stronger but i guess it wouldn't be a bad upgrade if you are already doing gears and such. go to the junkyard and pick up a whole one and then you even have a spare set of shafts.
if you find one that is a disconnect you just replace the inner seal and put your TJ shafts in it w/ a blocker plate and it will work fine.
