I bought a dodge Dana 44 from a ram charger because I thought the shafts and other parts would work on the wagoneer.
It looks as if the previous owner installed a new caliper, rotor and new pads. Axle is complete. and comes with mile marker aftermarket hubs. Gears are 3.23. Axle will come with factory dodge ram charger front leaves u- bolts, spring plates with sway bar attachement points. Axle is setup for spring over with the tie rod on top of the knuckles. Axle has some sort of vacuum deal on it like wagoneer. Tie rod is bent and the drag link has been cut in half. I also have an after market skyjacker lift arm that bolts to the top of the knuckle that I will throw in as well.
There are 3 leaves in the factory pack. 33" center pin to center pin. Springs are 48" eye to eye.
Will not Part Out!
Tamor price $175 anyone else $225
