When are you going to fix the color?
http://pirate4x4.com/forum/showthread.php?t=597198
http://www.pirate4x4.com/forum/showt...t=dana+60+stud
http://www.pirate4x4.com/forum/showthread.php?t=935812
Robbie here are some links to stud fixes. posted so I can find it.
The rear stud came loose from the housing due to fawked threads while the front stud was ok but slightly bent, probably due to shims but I need them.
I'll probably go the u-bolt route since it's the most shim friendly and remove the least amount of housing webbing possible.
4 wheels again, whoop!! I still have a ton of work to do, but I am getting there. I was on crack thinking I could have had this thing done by clayton.
I also reached my goal of beating Tate in having the bastard on 4 tires again.
Before one of you gun nuts wet yourself its a pellet pistol..
I would have had it on all 4 tires a while ago if ballistic fab would send me my damn towers. I really don't have much left. Bleed brakes, set 60 gears, hydro lines, cross member, driveshafts, t-case shifter, mount shocks, and exhaust. Probably more but that is all I can think of
Krosby Kustoms kicks off-road designs ass, we make our own chevy draglink to clear the engine crossmember. It was actually really easy to make and only took about 30 minutes to make.
link to the offroad design one
http://offroaddesign.com/catalog/Dana60crossover.htm
You are aware the ORD one is like 1/4 wall and threaded right? Not so sure about yours. For the record, my dragling is made from a rockwell tie rod, so its legit
I have an air over hydro setup on my bender .250 is not an issue.
Took some time off of working on the suspension and drivetrain crap to finish the floor, install the new bucket seats, and make a shifter/cupholder console so that I could double my current cupholder ratio and also have a good mount for the cable shifters.
looks good I like the console
