Page 105 of 132 FirstFirst ... 5 55 95 101 102 103 104 105 106 107 108 109 115 ... LastLast
Results 1,561 to 1,575 of 1980
Thread: Sloth
  1. #1561
    Respek TdmayfieldIV's Avatar
    Sep 2009
    Front body mounts
    All of the body mounts are now done. On schedule to have it movable and painted next week.
    F*ck off cj.
  2. #1562
    Sand Man Shaggy's Avatar
    Dec 2007
    San Antonio or Victoria
    Rigid?
  3. #1563
    Sep 2009
    Yep.........rubber mounts are for pu$$ies
    The cage is going to transmit engine vibrations anyway.
    F*ck off cj.
  4. #1564
    the bushings are to prevent metal fatigue, not to increase driver comfort.
  5. #1565
    Oct 2004
    Headed back to the Big D
    Well at least we know where that body is going to break in two
    also as a hint put your tacks on the corners of a plate you are going to weld and they will blend in much better. Tack placement is one of the keys to great looking welds
  6. #1566
    Apr 2006
    I'm betting metal fatigue will be the least of that broncos worries. Besides wouldn't using sandwich plates in the cage have a similar effect?
    Born to Kill
  7. #1567
    Quote Originally Posted by BroncoJo View Post
    yes, the body mounts eat all the sandwiches and become drowsy and fatigued.
  8. #1568
    Sep 2009
    I'll put some rubber on it.
    F*ck off cj.
  9. #1569
    Sep 2009
    F*ck off cj.
  10. #1570
    Sep 2009
    Metal fatigue from the vibrations or from the lack of flex in the mounts? If it's from the flex I can put some poly in between the bolt and the inside of the body mount.
    With the amount of run time this rig will see compared to a street legal truck, I'm sure that the effects of solid body mounts won't be that bad. Plus, since the body is skinnier, the flex won't be as bad.
    F*ck off cj.
  11. #1571
    Apr 2006
    The area around the sandwich plates you ****ing dip ****
    Born to Kill
  12. #1572
    Jun 2005
    Krazy Krosby
    That is why you make one plate larger than the other, so it does not act like an edge on a bending brake. Come on, didn't Stacy teach you guys anything?
    -Karl
    1965 Chevelle
    1975 Corvette
  13. #1573
    Big Baller 85cj7's Avatar
    Sep 2006
    The Big 'D'
    i dont speak australian.
    seacrest, you are my hero!
  14. #1574
    ****ing ********
  15. #1575
    Teaching America's youth RCcola55's Avatar
    Sep 2004
    with your mom
    Throw a piece of 3/8 belt material for tractor supply under there and call it good
    Ryan Clarke
    (214)695-7901
