no
needs more triangulation and more gussets
I know you aren't done yet
This may just yet avoid Bryan iron.....
What are you going to do with the steering column?
92 YJ
04 F-150 4x4
11 F-250 4x4
Pretty sure no on the orbital. The steering column is going to bolt to the dash that gets built into the cage. Tommy doesn't need more to do to get this done
Since I cut the booster/steering column out with the trans tunnel, the steering wheel is too far out.
The booster and pedal will stay, the steering wheel will be mounted to the cage.
Left to do
-Finish Cage
-Re mount steering wheel
-seats and harnesses
-wiring and guages
-front bumper and winch
-Gears
Bunch of little ****.
Cage and seats should be done by the end of the weekend, then wiring should take a day or two.
Won't the brake pedal be under your left foot where a clutch or e-brake should be??
