Rick Mar
Rick Mar
Ryan Clarke
(214)695-7901
I can't tell whats happening in that picture
Looks like TSL's? Are you having to do caliper grinding because they are a 15" rim?
-Karl
1965 Chevelle
1975 Corvette
I think he grinded down the calipers for them to fit. The ruh roh is probably for the parts that he's about to break now.
Really? a 16.5" does not clear? I guess it is the back spacing??? I know your axles are newer than mine, but mine clear 16.5's fine. 15's bring the suck.
-Karl
1965 Chevelle
1975 Corvette
problem solved:
2010 VW Jetta - DD, 5 Banger, 5 Speed, 1000 Watts of sound!!
1979 Ford Bronco Custom - 400/T18/205.. 35" SSRs, 4" lift, Rancho 5000s, 200 watts of sound!!
in 05 they moved to 14" rotors in the front and 13.75" rotors in the rear. I might have to take a 1/16th off the rear. But i'll probably have to take 1/4" off the front.
My 17" steelies have a little over a quarter inch clearance between the caliper and rim, so it would make sense that a 16.5" steely would barely touch. But, since they're aluminum they require a little grinding.
This seems remotely like usable tech information... WTF, get back to discussing porno...
-Karl
1965 Chevelle
1975 Corvette
Are you aware how bad those wheels suck? You better get some on board air, and a high lift, and starter fluid, and matches.
Keep it above 9 psi, they are ok.
-Karl
1965 Chevelle
1975 Corvette
Where did you get the tires from?
-Karl
1965 Chevelle
1975 Corvette
