Results 1 to 10 of 10
Thread: Ford Bellhousing
    Registered Eckert's Avatar
    Nov 2006
    Ford Bellhousing
    looking for a FE bell housing.
    thanks
    Tommy sucks Sharpe's Avatar
    Aug 2004
    Corpus Christi
    Eat a dick.
    Jun 2005
    Krazy Krosby
    Good point Sharpe.
    FE = 302 and 351W and straight 6 correct? I think I have an extra, it was attached to a 302 and the other side had a NP435 on it.
    -Karl
    1965 Chevelle
    1975 Corvette
    Apr 2006
    Good point Sharpe.
    The FE's are the 330's to 428's from the 60's and 70's
    Born to Kill
    Chief
    Sep 2008
    Ford FE Series
    332 cubic inch (1958 - 1959)
    * Compression ratio 9.5:1
    * Bore and stroke of 4.00X3.30
    * two-barrell @ 240 hp
    * 1958 series option w/four-barrell @ 265 hp
    * mechanical camshaft w/machined combustion chambers
    * last year of production, compression ratio 8.9.:1 @ 225 hp
    352 cubic inch
    * bore and stroke of 4.00X3.50
    * engine for the '58 T-bird
    * four barrell carb @ 300 hp
    * compression ratio 10.2.:1
    * cast iron crankshaft
    * forged steel rods, mechanical-lifter camshaft w/machined combustion chambers or cast chambers by 1959.
    * By 1960, the 352 HP was available with an aluminum intake manifold producing approximately 360 hp.
    360 cubic inch
    * Used in Ford trucks
    * Lower compression engine with heavy duty internal parts
    361 cubic inch (1958 - 1959)
    * Bore and stroke 4.0469X3.50
    * 10.5:1 compression ratio w/303 hp
    * In 1959, the 360 cubic inch used cast chambers reducing compression and horsepower.
    390 cubic inch (1961-1976)
    * Bore and stroke 4.05X3.78
    * Three versions available
    * 1961-1963: 390 cubic inch with 9.6:1 compression ratio, four barrell carb @300 hp.
    406 cubic inch
    * Introduced in 1962
    * Bore and stroke 4.13x3.78
    * Same block as 390 HP
    * Few 1963 blocks came with cross bolt mains.
    * Revised oil galleries.
    410 cubic inch
    * This is a 390 block with a 428 crankshaft
    * Four barrell carb.
    * The stroke is increased .020 in for a total of 3.98 inches
    * Only used in Mercury vehicles from 1966 to 1967
    427 Low Riser
    * Available through 1963-1964
    * Cast iron crankshaft and solid lifter camshaft
    * Intake 2.04 (2.09 inch in 1964) with 1.66 exhaust valves
    * Some of these engines had cross-bolt mains.
    * Cast aluminum intake manifolds.
    * Single and dual four barrell carburators.
    * Horsepower varied from 410 to 425 depending on setup.
    * 11.5.1 compression
    427 Medium Riser
    * 1965 to 1967 all 427 blocks were side oilers.
    * Forged steel crankshaft
    * Cap screw connecting rods
    * Cross bolt mains
    427 High Riser
    * Introduce in 1964
    * Tallest cyclinder ports and intake manifold allowed for greater air/fuel mixture
    * Cast iron crank
    * solid lifter camshaft
    * Cross bolt mains
    427 Tunnel Port
    * Available in 1967
    * Options included Tunnel Port cyclinder heads, four barrell aluminum intake or dual four barrell aluminum intake.
    * Much like the 427 medium riser in all other regards.
    427 SOHC
    * Available as an over the counter option only.
    * Cast aluminum cyclinder heads
    * hemi-spherical combusiton chambers
    * stainless steel valves
    428 cubic inch
    * Introduced in 1966
    * Bore and stroke of 4.13X3.98
    * forged-steel connecting rods
    * cast iron intake manifold
    * 345 horsepower @ 10.5:1 compression ration
    * Variations of the 428 existed throughout its' life span, including the 428 Police Interceptor, 428 Thunderjet and 428 Marauder.
    * The Police Interceptor contained an aluminum intake, high performance camshaft and beefier connecting rods to produce 360 hp.
    428 Cobra Jet
    * Standard was 2.09 inch intake and 1.66 inch exhaust valves.
    * Cast iron intake manifold identical to the aluminum one on the police interceptor.
    * Cast iron exhaust manifolds.
    * Two-bolt main block
    * Between 345-360 horsepower
    428 Super Cobra Jet
    * Internal structure differences included Lemans type cap screw rods
    * The capscrews were shorter than the 427's to clear the block
    * Externally balanced
    * External engine oil cooler
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    Thanks I sure Tyler couldn't use wikipedia or google to find all of that useless crap
    Quote Originally Posted by Hot Pocket View Post
    Ford FE Series
    352 cubic inch
    360 cubic inch
    406 cubic inch
    410 cubic inch
    427 Low Riser
    427 Medium Riser
    * Cross bolt mains
    427 High Riser
    * Introduce in 1964
    * Cast iron crank
    * Cross bolt mains
    427 Tunnel Port
    * Available in 1967
    427 SOHC
    428 cubic inch
    428 Cobra Jet
    428 Super Cobra Jet
    Jun 2005
    Krazy Krosby
    In that case, I am with Sharpe on this one, Eat a dick
    -Karl
    1965 Chevelle
    1975 Corvette
    Nov 2006
    actually, i had no idea what i wanted until he posted it. thanks hot pocket.
    does eating a dick constitute you or sharpe giving me a bell housing?
    Jun 2005
    Krazy Krosby
    Quote Originally Posted by Eckert View Post
    If the dick is Rowdy's and it prevents him from ever breeding, then yes, Sharpe and I will find one.
    -Karl
    1965 Chevelle
    1975 Corvette
    Chief
    Sep 2008
    glad I could help, came across that article a while back when I was doing some research of my own on Ford engines
