Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 47
Thread: Buckwheat
  1. #16
    Aug 2002
    fix that cv with a Dana 44, can't be that hard to hang a solid axle under, and it would be different.
    But I doubt it's as good a deal as John's ZJ
  2. #17
    Registered Eckert's Avatar
    Nov 2006
    did a little research for you...
    if your right about being an '87
    3.9L carb'd v6
    dont know what 5 spd, but the AX15 wasnt introduced until later
    np207
    and some shatty axles
    Im willing to bet it has the same trans as sharpes S10. and is worth about the same or less.
    on the other hand: unidbodys suck, as do 46RE's
    keep looking
  3. #18
    sam_hodnett's Avatar
    Feb 2010
    ETMF Land
    I will try to get pictures up as soon as i can of this truck... I have a few problems though... One, i dont have anywhere to keep it in college station this semester, and two, i really dont have a way to haul it around, but i am pretty sure i can get it down to college station if i do buy it
  4. #19
    Feb 2010
    ETMF Land
    I bought it Sunday for $600
  5. #20
    Sep 2006
    DFW
    For $600, beat the hell outta that thing just as it is!
  6. #21
    Dec 2005
    BFE, Tejas
    a little tube work and itll be sweet, not that it isnt for the price. good buy!
  7. #22
    Registered User
    May 2003
    Htown
    Step 1 - beat piss out of it
    Step 2 - TBD
    sweet deal!
    So you loose, I win!
  8. #23
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    http://houston.craigslist.org/cto/1668952418.html
    cheap parts truck with efi motor I would assume. Assuming the guy wants to play ball on the price.
  9. #24
    Feb 2010
    ETMF Land
    Thanks, What would have to be done to make it start without spraying gad into the intake?
  10. #25
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    I dunno prolly installing a new fuel pump. I bet he will take somewhere in the $350 range for it maybe less I'd start at like $250 and go up.
  11. #26
    Feb 2010
    ETMF Land
    Thats what i was thinking, its just a long way from home for me to tow it all the way back to paris
  12. #27
    Feb 2010
    ETMF Land
    Bump
    Re-named, Buckwheat
    I have a 96 Cadillac with a 4.8L V8 that is sitting in a pasture on my ranch for a few years, it is a front wheel drive car, but i only need the motor, can i put it in Buckwheat? any reasons not to?
  13. #28
    Jan 2010
    If you're going to swap motors, you might as well do something like a 350 that's easy to find parts for. A caddy wouldn't bolt up to anything would it? So I don't know why it would be a viable option at all.
  14. #29
    Jan 2006
    DAAAnngerrr Zone!
    I vote for something easier also. Did the 4.8 ever go in front of anything rear wheel drive? Is the car still driveable? If so, maybe list it on CL as a trade for a drivetrain, and save a big headache.
    'Cause if she don't,
  15. #30
    Boost Junkie breckboarder55's Avatar
    Sep 2008
    CS
    Quote Originally Posted by sam_hodnett View Post
    Bump
    Re-named, Buckwheat
    "Northstar V-8
    The candidate: In '93, grannymobile Cadillacs began running GM's premier DOHC 4.6L Northstar engine. With dual overhead cams, four-valves-per-cylinder, and an output of either 275hp/300lb-ft (LD8) or 300hp/295lb-ft (L37), the all-aluminum Northstars combined light weight, high strength, and smooth power delivery in one iconic package. The catch was that up until the LC3 came along in '07, all Northstars were transversely-mounted in front-wheel drive applications.
    The perception: I'll buy a '90s Caddy for $800, yank the engine, and slap it in my Wrangler and go!
    The reality: The transverse-mounted architecture is a nightmare to overcome. For starters, the log-style oil pan can't be chopped into a rear-sump design. Then, the intake manifold must be turned 180-degrees on the engine and the water pump manifold and water pump removed from the rear of the engine and replaced with an electric water pump for firewall clearance.
    The exception: The engine architecture works well for rear-engine sand rail applications and, indeed, these engines are supported with aftermarket wiring harnesses and stand-alone ECUs.
    We think: Leave 'em to the buggies. If you really need a DOHC Northstar, go find yourself an Olds 3.5L Shortstar V-6, add a turbo, and pretend you're running the V-8."
    Sounds like it would be a bitch, if you want a cheap V-8... Go with a you know what...
    SHUT UP AND WHEEL
