Yes extended the frame and am running a reverse swinging steering box. See my build thread for further details.
ASTRO VAN? i don't feel like reading your thread
Fullsize van. Astro boxes were mounted inside the frame
Got the rear axle mostly moved 14 inches forward. That'll give me a 120" wheelbase when I move the front axle 3" forward. Going to work on pulling and selling/scraping the 360/np435/Dana 21 this week so I can put the 460/c6/1354 in and then build driveshafts and dominate the Baja course. I also have some tube to get started on the cage. Just need to find some buckets for it.
Got the motor and trans pulled. List of things to do before I put the new motor in:
Front axle
Disk braked rear axle
Brake lines
Steering
Cage
Find narrow 8 lug steel 16.5 rims
I also have to figure out if I can make the speedometer work with the new stuff.
Any other tubes I should add for just a simple cage? All the legs will got to plates that sandwich the floor with rubber insulators and then to the frame. Also going to tie whatever seats I get into the cage and sliders.
They aren't door bars, they're supposed to help keep the cage from folding forward or back. I'm either not running door bars or I'm running tube doors but that's down the road.
Probably.
That's not a hard bend at all. Just bend up a hoop, then turn it 90 degrees to level and put the kinks in it.
rear down bars?
Seth Stewart '04
2000 Suburban DD
1998 GMC pickup - sold
1975 Scout - TBD
1976 Scout - parts truck
1972 IH 1310 dually - TBD
196? Scout 800 - 302 roller
Could maybe eventually tie the cage into some shock hoop contraption when I get coilovers.
