Just like the title says, I'm selling it all. It is a long story, but let's just say life has won and I'm throwing in the towel. I'll go back and add pictures of this stuff later.
1974 IH ScoutII (aka Lurch)
345 v8/727 trans/dana 20 tcase/dana 44s with 3.73 gears and lockrights front and rear. Doesn't look like much, but it has been one of the most reliable trail rigs in the club. Current registration and inspection. Passes every year without trouble however it needs new tires. $3000 obo.
1971 IH Scout 800
Light green with off white full top. Does not run. 304v8,T19/Dana 20, d30 front and d44 rear from an early scoutII. Bought this to build a new trail rig. Solid truck with clear Texas title. $1250 obo.
1965 IH Scout 80
All original half cab truck. Missing doors and the 152 4cyl. Still has original trans/tcase and axles. Also a good candidate for a build. Has clear Texas title. $500 obo
1976 Dodge 3/4 ton 4x4 truck
Not the prettiest truck, but a great parts donor. Built 440 backed by a 727 mated to an NP203. Dana 60's front and rear with 4.10 gears. Clear Texas title. $2000 obo
1992 Camaro "RS" Convertible
There is a buildup thread on this in the projects section that shows a history of this thing including its latest damage. Would like to get $6000 for what is left of it. There is at least twice that in parts in it. Has clear Texas title.
1992 Camaro RS hardtop
I bought this to try and combine parts from this and my convertible to make one car, but I don't even care anymore. This car has a 350/700r4 and disc brake 10bolt rear. Does not run. Clear texas title. $600 or I can make a package deal on both camaros.
Edit: Here are some parts.
Ok, here's some parts:
5.3L Vortec V8. 2001 year model, was told by Dogget's when purchased that it had 58,000 on it. Comes complete with all belt drive accessories, exhaust manifolds, MAF sensor, computer, and stock harness. $800
GM SM420 transmission, not rebuilt, but in great shape $75
GM SM420 transmission, rebuilt, with Novak Mainshaft conversion and adapter kit to Dana 300 already installed along with tcase clocking ring. $500
Jeep Dana 300, not rebuilt, but in great shape $200
Dodge 203 range box. I have the rest of the case, but I planned on using it in a doubler setup, so I separated it. Make an offer.
Hummer H2 wheels (set of 4) , in perfect shape. $225
Warn External Hubs, p/n 9062 brand new. Make offer
Comp Cams pn/ 850-16 87-UP SBC/LT1/LS1 Roller lifter set, brand new in box. $150
Comp Cams 941-16 Valvespring set, brand new in box $100
Installed Height (in) 1.750 in.
Seat Pressure at Installed Height (lbs) 130 lbs.
Open Height (in) 1.250 in.
Open Pressure (lbs) 350 lbs.
Don't know if anyone is into paintball or not, but I'll throw it up here in case.
Tippmann A5 with a couple barrels, 20oz co2 tank, case, cleaner, spare parts, and Tippmann response trigger as well as stock trigger. $150
I'll put up more as I go through stuff. Like I said, I probably will start listing stuff on craigslist this weekend.
