Results 1 to 15 of 15
Thread: Dana 44 HP Narrowed
    Registered User ol burj's Avatar
    Oct 2008
    Dana 44 HP Narrowed
    Dana 44 HP narrowed, was told it had 4.56 gears in it, havent bothered to look though. Lock outs work fine, would probably fit into an xj or something with a little fab.
    $250 obo
    Nov 2002
    Tx
    What's the WMS? Is it bare or does it have the radius arm wedges?
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    It is most likely an early bronco Dana 44 not a narrowed one.
    Oct 2008
    it has the radius arm wedges and they are cast not separate pieces and the wms is about 60" or less
    Registered Eckert's Avatar
    Nov 2006
    yeah, its got to be an EB axle. dont know how you would go about narrowing a cast 'c' d44.
    out of curiosity, drum or disc?
    Nov 2002
    Tx
    EB 44 would be welded wedges wouldn't it?
    Quote Originally Posted by mudtoy67 View Post
    believe so
    eb wouldn't be high pinion.
    Oct 2008
    disc brakes
    Nov 2006
    pics...
    if you check and verrify the gears that would help it sell
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    It s the axle that was on tx4x4 for the past couple of weeks. There were some pics there.
    Oct 2008
    this weld is partly what makes me think its been shortened. its on the passenger side wedge/inner tube.
    And this shows how to shorten this type of axle
    http://www.therangerstation.com/tech...ord_dana44.htm
    Boost Junkie breckboarder55's Avatar
    Sep 2008
    CS
    WMS? Passenger side drop? ETC?
    SHUT UP AND WHEEL
  15. #15
    i bought it. i just wanted the brakes from it for a cj thing i'm doing on a blue 7. so if you are interested in the rest let me know. i would take the hubs rotors and brackets. so u would get spindles in. 4.56 gears . i will measure it later
