Hey yall stay away from my spindle.
it wouldn't save my EDIT so I am just reposting here:
Toyota Parts:
EDIT: $275 - All-Pro Chrmollly axle shafts with installed bearings, seals, bearing housings, studs and lug nuts. These shafts only have two runs on them
EDIT: 4cyl 3rd member with stripped 4:10 gears, Lincoln locked
(4) Toyota OEM rear axle shafts– wide
Flem - (1) welded 4cyl carrier
Flem - (1) V6 3rd member with caps
Flem - $50 (1) V6 3rd member w 4.10 gears, Lincoln locked
$20 (1) V6 4:10 reverse cut (high pinion) gears on Lincoln locked carrier
Toyota 4.56 gears
(2) vented Toyota rotors
(2) 4 piston Toyota calipers
$20 - Toyota pitman arm, All Pro (old school), double sheer
$40 - Toyota steering box, drilled and tapped
Warn premium hubs for IFS truck, one has water damage and needs to be rebuilt with new parts
Other Crap:
Ed - $300 OBO Warn 8K Winch, M8000, cable is not in great shape but still works fine.
Ed - $30 Warn 8K winch cable, brand new
Ed gets one - (2) roller fairleads, one never used - $10
Set of Ford 9” shafts, 28 spline, I think small brg
D60 open carrier
Busa - D60 4:10 reverse cut (high pinion) gears - OEM
Karl - (2) D60 Ford knuckles
Karl - (2) D60 caliper brackets, cleaned and painted, Ford
Kolpecker - (2) D60 Bearing hubs – Dodge external lock
Busa? - Dodge D60 spindle
Jerry -Box of Dodge mirrors – broken glass 2nd gen tow and stock sets
(2) Dodge chrome dually wheel insets
(2) multimeters - old school
Chevy 5.3 manifolds (2000 vinatge)
Dropped pitman arm – Dodge?
4” lift blocks
Sharpe - Free - (2) Bilstein B46-1072S shocks – need rebuild
Still plenty of stuff to get
Scott, FTAC '99
'89 "CJ-7" - Her trail rig
scott.schubring@williams.com
I will take both of the multimeter I will get at Alto just put with eds crap
do you remember which mirror was busted on the tow mirrors cause i have a good pass side tow mirror for a second gen
Scott would you have any dodge 60 front spindle studs? I need three or four to complete my axle, if so can you bring them to jerry's?
if this stuff can make its way to college station I could use the toyota axle shafts, calipers and rotors.
not sure which one is broken, will find out tonight.
no spindle studs
the stock rear shafts of the All-Pro ones? I hope someone can take this stuff to CS, I'd sure like to get rid of these shafts and brake crap...
Scott, FTAC '99
Come to my parents on Sat and they can come get whatever there.
Jason, I have the calipers and rotors. Find me at alto or I will send them to College Station with someone.
Scott, FTAC '99
