Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 55
Thread: Shock Problem?
    MR.ZAP's Avatar
    Sep 2009
    San Antone
    Question Shock Problem?
    Hey guys, my jeep has been exhibiting somewhat of a gangster lean as of late... Is this a shock issue and if so should i replace all of them or just the ones on the leaning side?
    probably not shocks.
    what brand springs do you have? Is everything seated correctly in the spring buckets?
    Jun 2005
    Krazy Krosby
    Shocks limit vibration and sway, they do not affect ride height.
    -Karl
    1965 Chevelle
    1975 Corvette
    lowballing someone
    Feb 2005
    Houstonish
    air shocks do but thats a completely different type of shock.
    check your springs and make shure they are in the right location, make shure one didn't break (it happens) and if all else fails take out the tape measure and give everything a measure and compare. i have no clue if your shocks are worn but a bad shock will not cause your issue
    or maybe just get the fat chick out of your passenger seat.....
    MR.ZAP's Avatar
    Sep 2009
    San Antone
    I really couldn't see any striking difference. If anything it's that right rear spring. They are off of a 4 door Rubicon w/ tow package so OEM.
    I'd try swapping sides. They may not be the same spring rate on the passenger and driver side.
    MR.ZAP's Avatar
    Sep 2009
    San Antone
    I think they do but they've been on for a very long time so shouldn't I have noticed by now???
    Oct 2004
    Headed back to the Big D
    maybe the weaker side is just getting worn, coil springs do sag, it is probably all of that amazing torque that the 3.6Ls of fury produces
    MR.ZAP's Avatar
    Sep 2009
    San Antone
    Quote Originally Posted by AggieTJ2007 View Post
    It's possible but they shouldn't be doing that, they aren't old springs, they were brand new when I got them... and it's a 3.8L, ass****
    Oct 2004
    do you have lift pucks or longer shocks you can over compress and/or overextend stock coils pretty easily and it takes the life of of them quickly.
    My lift springs on the TJ lost almost 2 inches in 2 years of good wheeling
    MR.ZAP's Avatar
    Sep 2009
    San Antone
    I have 2 inch pucks and the HD springs.
    lowballing someone
    Feb 2005
    Houstonish
    have you got out a tape measure yet and measured the height of the springs as it sits and compared them......
    MR.ZAP's Avatar
    Sep 2009
    San Antone
    After further inspection it looks like my right rear spring has unseated itself from inside the puck and is now kinda sitting on the edge... Also I measured and all of them were uniform.
    Oct 2004
    Well it looks like you found your problem
  15. #15
    MR.ZAP's Avatar
    Sep 2009
    San Antone
    Yeah, seems like it. Now I just have to find someone to help me fix it
