Located in Jersey Village (NW Houston)
pics:
https://picasaweb.google.com/scott.n.../ForSaleStuff#
Prices are negotiable, I am cleaning out the garage and just can't see tossing all of this in the trash
Toyota Parts:
SOLD – late model (86~95) Toyota All-Pro Chrmo shafts
$30 - (3) Toyota OEM mini-truck rear axle shafts– wide (late model)
SOLD – Complete Toyota FJ-80 front axle.
$50 - (2) FJ-80 OEM front longside inner axle shafts
$20 - FJ-80 OEM front shortside inner axle shaft
$80 - (4) Aisin hubs, two with IFS slugs, others empty. Need rebuild. (3) Aisin hub lock dials, one w/o gear
$30 - bearing hub mounted on spindle with bearings (used as spares to hold spare tire in bed) THIS IS A COOL WAY TO CARRY SPARE PARTS
$30 - (2) 22RE AC Compressors (I use for on board air)
$20 - Toyota 8” V6 4:10 reverse cut (high pinion) gears on welded carrier
$50 - 8” 4.56 Richmond 4cyl gears
$30 – Toyota driveshaft (used as spare)
$10 – radiator from ’91 truck with 22RE, small crack at outlet that can be welded
$10 - tilt steering column from ~'95 truck. Lock removed, switches work
Other stuff:
pending - (1) Warn roller fairlead, never used, still in bag
Free - Set of Ford 9” shafts, 28 spline, I think small brg
$10 - D60 open carrier
$20 - (2) Dodge chrome dually wheel insets ($90ea online)
$25 OBO - Chevy 5.3 manifolds (2000 vintage)
$25 OBO - Chevy 6.0 exhaust manifolds (2002 vintage)
$10 OBO – heavy duty weld on leaf spring perches, drilled with three holes
Free - Dropped pitman arm – Dodge?
pending - 4” lift blocks from 1999 Dodge 2500, good cast ones with built in angle
