Results 1 to 2 of 2
Thread: tekonsha prodigy 90185
    Big Baller 85cj7's Avatar
    Sep 2006
    The Big 'D'
    My little sister has sold her trailer and now has no need for her trailer brake controller. She still have everything it came with and it is in the original box. She payed $135 for this great controller and was hoping sell it for $75 since it has only been used in one vehicle and the original wiring hasn't been cut since she used a ford pigtail adapter. Basically brand new and ready to go into your vehicle. She lives in Colorado Springs so shipping would be an extra $10 (i think) for USPS flat rate.
    i dont speak australian.
    seacrest, you are my hero!
    Sep 2006
    The Big 'D'
    Some details she sent me. . .
    Tekonsha Brake Controller with Wiring - 90185-3035P
    Tekonsha Prodigy Electric Trailer Brake Controller with Ford Adapter
    Tekonsha introduces Prodigy, one of the most advanced and intelligent approaches to trailer brake controls. Prodigy, requiring no manual leveling, is a technological breakthrough among inertia-activated brake controls. Equipped with a self-adjusting sensing device similar to the one used in guided-missile technology to allow for easy, flexible installation - from nearly horizontal to nearly vertical - the Tekonsha Prodigy constantly adjusts itself to the position of the tow vehicle.
    Features:
    •Applies power to the trailer brakes in proportion to vehicle's deceleration.
    •No level adjustment necessary - it adjusts itself to varying terrain as you drive.
    •Works proportionally in reverse - great for backing into tough spots.
    •Digital display depicts voltage delivery to trailer during braking.
    •Continual diagnostics check for proper connection, shorted magnet condition and much more.
    •"Boost" feature gives users the ability to apply more initial trailer braking power when towing heavier trailers.
    •Power-saving mode reduces drain on battery when vehicle is not in use.
    •Unique pocket mount allows for flexible mounting options.
    •Quick and easy disconnect feature allows user to remove and store the control when not in use.
    ◦Vehicle specific wiring adapter is included to make installation simple
    •Rotary manual brake adjustment lever
    •Limited lifetime warranty
    Specs:
    •Dimensions: 3-1/8" Wide x 5-1/8" Long x 1-3/16" High
    •Made for up to 4-axle trailer brake systems (2 to 8 Brakes)
    •Can be mounted between 0 degrees (level) and 70 degrees
    •Boost levels increase power up 0%, 13% and 25%
    •Power saving sleep mode draws 3.6 milliamp
    •Version 2.6
    Installation:
    The vehicle specific adapter has one end that plugs into the back of the brake controller while the other end plugs into the port located under the dash.
