Results 1 to 6 of 6
Thread: Need a V8 radiator and fan & 305 clutch parts
    Registered User jasonjuch's Avatar
    Sep 2008
    Im looking for a radiator that I can mount in the back of my toyota after i put the 305 in. Also any kinda input on what kind of electric fan to put on that.
    Also need clutch components for the 305, 11" pressure plate, chevy throw-out bearing, info on what kind of clutch i can run betwen the 305 and my w56 transmission.. advance adapters says use their special 10.5inch clutch(http://www.advanceadapters.com/products/pn-712560v/) but i heard you can use regular clutches as well... And yes I know its a v8 and a toyota transmission ive heard that a few times
    85 yota, 305 on propane, 4.7 t-case, 37" hummer tires on H1 beadlocks, rear welded
    lowballing someone
    Feb 2005
    Houstonish
    corey has a good clutch, flywheel plate etc he would sell you. cjnut if you didn't know his screen name
    Sep 2006
    DFW
    Quote Originally Posted by jasonjuch View Post
    I wouldn't worry too much about that. The 305 didn't produce that much power I think you will be fine. Good to see you are going through with it.
    Respek TdmayfieldIV's Avatar
    Sep 2009
    It's going to be hard to find a used radiator. Especially when they are worth 1.85 per pound at the j/y.
    Sand Man Shaggy's Avatar
    Dec 2007
    San Antonio or Victoria
    I have the radiator from the bronco and also a huge one from a cat dozer.
    Jonathan Tate
    361.676.6466
    2004 Jeep TJ
    1992 Jeep YJ
    2008 Jeep JKU
    Sep 2008
    thanks ill send him a pm
    thanks ill send you a pm
    ive been making good progress, its back in austin in my dads garage so its taking time to make time. The propane system is all mounted in, the engine mounts are ready to be welded in and then the clutch stuff needs to be figured out. It shouldnt be much longer
