Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 53
Thread: Chevy Tbi problems
  1. #16
    let me check tomorrow. I didn't know you could do it with a paperclip.
    http://tr6.danielsonfamily.org/TBI_15.htm
    heres a list of tbi codes btw frick
    F*ck off cj.
  2. #17
    12, 13, 59, 67, 75, 81, 82
    F*ck off cj.
  3. #18
    DTC - 13 Oxygen sensor circuit open or no activity
    DTC - 13 Left bank O2 sensor circuit open or no activity
    DTC - 59 Trans fluid temp sensor circuit error (high voltage)
    DTC - 67 A/C pressure sensor circuit error
    DTC - 75 Digital EGR solenoid #1 circuit error
    DTC - 82 3x Crankshaft position sensor circuit error
    And I got a #81, which doesn't exist
    F*ck off cj.
  4. #19
    Hazaa Fredo's Avatar
    Sounds like a bad ecm/chip. How did you mount the computer?
  5. #20
    Behind the glovebox. Suspended in zip ties.
    F*ck off cj.
  6. #21
    I pulled the chip out (it had come loose) and put it back in. It runs fine now.
    Found this on pirate. I'll be changing pumps to see if I can find more top end.
    http://www.pirate4x4.com/forum/showthread.php?t=727927
    F*ck off cj.
  7. #22
    tbi doesn't like to much pressure iirc
  8. #23
    So I unplugged the memcal and put the stock chip in and it ran like ****, then I put the burned chip in and it ran better and the check engine light went off and it's running less ****ty (i'm sure it will return).
    So it is reading the chip. My next guess would be the 02 sensor. Maybe all of the codes I listed earlier were stored from the old truck it was in?
    F*ck off cj.
  9. #24
    Starts up immediately
    Idles ok, not too smooth
    500-1000rpm seems about normal. good throttle response
    1000-2000rpm Under load it stumbles and hesitates
    2000-2200rpm seems to realize it's ****ing up and catches itself. Stops stumbling and runs normal
    2200 rpm + Continues to run like ****
    F*ck off cj.
  10. #25
    Chief
    Sep 2008
    Invest in a 2bbl 2150 and run it on propane. There's a reason they call it fool injection
  11. #26
    You sir are an idiot.
    F*ck off cj.
  12. #27
    Sounds like you might have the distributor wired backwards to the ecm. Try flipping over the wiring on the circled plug below.
  13. #28
    I'm stupid. I meant to circle this one. Check this pic.
  14. #29
    Thanks Fred ill try that
    F*ck off cj.
  15. #30
    If you're good at something...
