Results 1 to 14 of 14
Thread: 96 Tacoma - SAS, Diamond Axle, Dual Cases, Flopped Cab - $8,000 OBO
Hybrid View
    DFW
    My Truck is for Sale. I think I found a buggy I want (or want to start moving towards).
    Thing will Wheel. It truly works, dependable, reliable, when the tires are aired up I have had it at 65 no problem (it was just chilly with no windshield. Heat and AC work, just a smashed cab is all. I probably have, with purchase price $22K - $23K in it. You can see the list of Parts below, no expense spared, 14K just in the parts. I love it but ready to move on.
    Has regular doors and tube doors, will obviously include both. Thing has tackled some of the hardest terrain in Clayton including Green Momba and Green Momba's Extension (with my driving skills!). Will crawl super low.
    Put together a list of just the parts on it:
    Drivetrain
    FROR Tacoma Crossmember and Skidplate Combo $349.00 http://frontrangeoffroadfab.com/nfos...products_id=34
    Marlin Crawler Built Tacoma Double Transfer Case Setup, 4.7:1 $1,995.00 http://www.marlincrawler.com/transfe...unit-mc09-t360
    FROR Tacoma T-Case Twin Sticks $189.00 http://frontrangeoffroadfab.com/nfos...products_id=36
    Axles
    Tacoma Custom Width Diamond Axle Housing $900.00 http://www.diamondaxle.com/front_steering.htm
    Custom Length Longfield inner axles $330.00 http://www.longfieldsuperaxles.com/p...LE-SHAFTS.html
    Longfield Birfields $430.00 http://www.longfieldsuperaxles.com/p...-BIRFIELD.html
    Tacoma Brake Mounting Kit $99.00 http://frontrangeoffroadfab.com/nfos...roducts_id=136
    Front Toyota 8" V6 3rd With 5.29 Gears, Detroit Locker and Solid Pinion Spacer $1,124.00 http://eastcoastgearsupply.com/i-157...-8-v6-3rd.html
    Rear Tacoma Non ELD/ T100/ Tundra 3rd With Detroit Locker, 5.29 Gears and Solid Pinion Spacer $1,235.00 http://eastcoastgearsupply.com/i-788...undra-3rd.html
    Steering
    FROR Full Crossover Steering Kit $399.00 http://frontrangeoffroadfab.com/nfos...products_id=93
    All Pro Rebuilt IFS Steering Box $399.00 https://www.allprooffroad.com/pickupsteering/246
    Suspension
    FROR Tacoma Solid Axle Swap Kit $199.00 http://frontrangeoffroadfab.com/nfos...products_id=38
    Diamond Spring Perches - $40/pr $40.00 http://www.diamondaxle.com/parts.htm
    Diamond U-Bolt Flip Kit - $69 per axle $69.00 http://www.diamondaxle.com/parts.htm
    All Pro 5" Front Long Travel Leaf Springs $269.00 https://www.allprooffroad.com/pickup...kupleafsprings
    Front Bilstein 14" 5125 Shocks $158.00 https://www.allprooffroad.com/pickup...ckupshocks/301
    Trail Gear Universal Shock Hoop Kit $52.00 http://www.trail-gear.com/shock-hoops
    Tacoma Steering Box Mount & Frame Plate Kit $149.00 http://frontrangeoffroadfab.com/nfos...products_id=46
    Custom Rear Alcan Leaf Springs for pre 97 Tacoma $349.00 https://www.allprooffroad.com/9504ta...504leafsprings Don't remember price so going with All Pro lesser springs for price comparison
    Rear 5125 - 12" for Lifted Applications (BE5-6249-H5) $158.00 https://www.allprooffroad.com/9504ta...rearshocks/301
    All Pro Rear U-Bolt Flip Kits $49.00 https://www.allprooffroad.com/9504ta...04uboltflipkit
    All Pro Short Shock Mounts $29.00 https://www.allprooffroad.com/9504ta...504shockmounts
    Armor
    Rocktek Custom Front Bumper $499.00 http://www.rocktekcustomz.com/
    Rocktek Custom Sliders $359.00 http://www.rocktekcustomz.com/
    4x4Inovations Tube Doors - 95.5-04 Tacoma Tube Doors $215.00 http://4xinnovations.com/p-TD03.html
    Tube Bed and Roll Bar Custom $500.00 Custom Made
    Wheels and Tires
    Trail Worth Fab 12 bolt Double Beadlocks, Powdercoated Hammer Black with Pressed Centers, 6x5.5 bolt pattern and PVC Inserts. Full Rock Rings $1,219.80 http://www.trailworthyfab.com/-175-1...l-Special.html
    Pitbull Rocker Radial Tire 37x12.5 R16.5 $1,559.80 http://www.4x4groupbuy.com/store/pit...5-p-11493.html
    Accessories
    Superwinch 8500lb Winch with Synthetic Winch Line $449.99 http://www.northerntool.com/shop/too...2430_200422430
    IPF Lights $99.00 http://www.trdparts4u.com/scripts/pr...?idCategory=21
    Modifications Total $13,871.59
    sam_hodnett's Avatar
    Feb 2010
    ETMF Land
    A while ago you told me you had a new line on a cab for it. Do you still have said line?
    It is hard to tell from the pics you posted, but could the cab be fixed? Not necessarily back to new fixed, but fixed enough to get a windshield in it and a functioning door back on it?
    Feb 2010
    ETMF Land
    Quote Originally Posted by JB View Post
    I think it could be possible, it wouldnt be super pretty, but with the correct amount of work it could be done
    Dallas, TX
    Chris - Have you checked into this or talked to any shops about what would be involved?
    DFW
    Yes the bumper would be compatible but it will have to be cut off and welded to your truck.
    DFW
    The cab can definitely be fixed enough to put a windshield in. I don't know how pretty it would be though . Sorry Sam the cab I knew of sold a long while back.
    Registered User 93yotaSAS's Avatar
    Sep 2011
    would you be willing to part with the tube bed?
    DFW
    No not until I was ready to part the entire truck, which I might be in the next month.
    Sep 2011
    Well let me know when you decide, cause im definitely interested
    Toot! Toot! 4-Banger's Avatar
    Sep 2007
    DFW for now
    Would that bumper be compatible with a '99 Taco?
    I may not be able to run with the big dogs, but I can limp with the pack.
    DFW
    I have not, haven't felt the need to. I guess in my mind I only considered replacing all of the body on the truck because I would want it absolutely perfect again. Dunno why though?
    Anybody have a body shop in the DFW area they trust?
    DFW
    Bump, putting it on Pirate. Woman reminded me this weekend I was supposed to sell it.
    DFW
    Sold.
