Here's the deal. I've got dibs on Davido's extra set of a D60/14 Bolt. And I really do like the Dave Performance Package using the axles full width with hummer wheels. But the front hubs will be problematic. So I am thinking of doing 35 spline drive flanges. I have some questions regarding this. Through my searching I've discovered that the conversion uses the flanges off a rear FF-D60. But I have not seen the actual list of parts. So the questions follow:
1. Does it use the stock front spindle or the rear spindle?
2. I know new stub shafts are needed, but I understand the slugs and flanges come from the rear 60. I am not terribly familiar with the FF D60. I assume that the axleshafts don't have integral flanges but are splined on both ends. Is this ture?
3. I am also assuming that the hub from the rear is used too. If true, does it use the same bearings and seals or do spindle differences require different parts.
4. Parts Needed: From Rear FF-D60: hubs, spindles?, bearings and seals?, flange, slug, nuts and lockwashers. Anything else?
Flem and Cajun, I know you guys are a weath of trivia in this area so chime in.
-Mark
