Page 10 of 13 FirstFirst ... 6 7 8 9 10 11 12 13 LastLast
Results 136 to 150 of 188
Thread: Tug II
  1. #136
    Jan 2010
    Quote Originally Posted by Sparling View Post
    inb4 what were you thinking buying a wonton rice wagon
    Complaining about the way a 3/4 ton truck rides..... Just sayin.
    Just sayin.
  2. #137
    Apr 2006
    5" or 7" deavers, no blocks, some kind of traction aid.
    I don't understand why you want to add so much height, just saying.
    Born to Kill
  3. #138
    sam_hodnett's Avatar
    Feb 2010
    ETMF Land
    Quote Originally Posted by BroncoJo View Post
    I agree. Just saying
    I also agree on 05 axles. Just saying
  4. #139
    Jan 2010
    Not really adding height. The block is 4 inches in the back. The 5" would raise the back an inch and the 7" would go with a 2" longer shackle. The truck sits perfectly level now, but looks like the ass is sagging so I'm going to put a hair of a rake on it.
  5. #140
    Jan 2010
    Just sayin
  6. #141
    Tommy sucks Sharpe's Avatar
    Aug 2004
    Corpus Christi
    Go much higher and you're gonna have to call Tate's guy at Pitbull for some 40s.
  7. #142
    Respek TdmayfieldIV's Avatar
    Sep 2009
    Quote Originally Posted by sharpe View Post
    go much higher and you're gonna have to call tate's guy at pitbull for some 40s. Just sayin
    fify
    F*ck off cj.
  8. #143
    Jan 2010
    Quote Originally Posted by TdmayfieldIV View Post
    fify just sayin
    Dumb dumb tumtum. Just sayin
  9. #144
    Sep 2009
    Damn n00b mistake....just sayin
    F*ck off cj.
  10. #145
    Registered User zebvance's Avatar
    Oct 2012
    college station
    What is your shackle angle at and what shocks are you running. Sorry if It was mentioned somewhere before and I missed it.
    1988 Comanche auto, 4.0, 4x4, 8.8 rear trussed, Dana 30 trussed, SYE np231, Serious Offroad long arms, 9.5" of lift, 35's, lockers
  11. #146
    Jan 2010
    Shackle is straight up and down, and I'm running procomp adjustable shocks with the knob all the way to the left which should be loose.
  12. #147
    Jun 2005
    i would take off those shocks and test drive!!! I got those for my fabtech lifted truck, did not last long, way to harsh. I think carli or one of the other higher end dodge suspension companies was doing a custom valved king for fords now that fits the stock mounts
  13. #148
    Jan 2010
    Carli has custom valved King shocks and Fox has a factory replacement line.
  14. #149
    Oct 2012
    college station
    Try relocating the shackle angle to 30-45 degrees from the frame rail. Thats suppose to be the best set up for ride quality. The greater the shackle angle the more force is exerted down on the spring and in turn the spring rate gets lower. I imagine you will notice a lot from doing this. Especially if your shackle is straight up and down like you said. That should be 90 degrees which would be the stiffest configuration you could have.
  15. #150
    Jan 2010
    Even on tension shackles? Everything I can find on shackle angle is for compression shackles. Either way, I'm going to hold off on moving leaf spring hangers until I get deavers.
