TAMOR Obsession
Diesel Injectors
Sorry for the new thread, but I couldn't find the thread where eight questioned the ability to test injectors....
It is a test done with an OBDII scanner called a "Cylinder Contribution Test". The computer turns off each injector one by one and I guess measures RPM drop. If your truck is already running like crap and you suspect an injector you can tell which cylinder isn't firing. As each injector turns off the truck runs poorly. If the computer turns one off and the truck doesn't run much different, then you know which injector is bad...
TAMOR Obsession
I passed the test. The truck shakes a little bit after I come to an idle from being on the highway. I put some fuel additive in the tanks and I'm going to change the filter tomorrow.
Somewhere in the future I want to get a new down pipe, chip, pyrometer, and boost guage. This is all after a spray in bedliner, tool/fuel box, and a trailer (mostly funded by my work).
- You may not post replies
- You may not edit your posts
Forum Rules
