Page 6 of 11 FirstFirst ... 2 3 4 5 6 7 8 9 10 ... LastLast
Results 76 to 90 of 162
Thread: JB's TJ
  1. #76
    Oct 2004
    Headed back to the Big D
    Quote Originally Posted by TdmayfieldIV View Post
    You're such a jeep douche. Why are you putting bigger tires on your jeep? You're just gonna break stuff you stupid butthole!!! Those fenders look gay and make your jeep look super rice.
    Quit modifying your vehicle, you don't need bigger tires.
    This would be a valid point if it were his only mode of transportation and responsible for towing his ranger to alto
  2. #77
    Apr 2006
    Ya jeeps are rice too!
    Born to Kill
  3. #78
    ill be your pickup man
    San Antonio, Tx
    Maybe I had too many garage beers last night.
    All I did today purple power it down, fix a pinched vaccuum line, and topped off the trans and radiator. Drove it now and seems fine.
    The sender is directly over the oil filter right? DUmb, but I unplugged it and plugged it back in and now it is back to reading somewhat accurate
    I drained a little oil, and it was not obvious that there was water in it. Seemed fine.
    And yes, that big line is an AC drain line. Kinda in a bad spot, but I can cut it a little shorter.
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
  4. #79
    Jan 2006
    DAAAnngerrr Zone!
    Need to change the title of this thread to Rice-a-roni....
    'Cause if she don't,
  5. #80
    San Antonio, Tx
    The Jeep did great at DSO, even in the heat. I still am having an issue with the shifter even with the AA bracket. I need to figure that out.
    The sway bar hits the PSC inner fenders. I can easily cut them, but what should I do about the sway bar? That sounds like the gayest Jeep questiom ever, but should I really just buy disconnects? Or just unbolt it when wheeling?
    What about this setup?
    *chromos/detroit in rear 44
    *chromos/selectable in Rubicon front 44 (or RCVs)
    *2" coil lift with decent shocks (5100s)
    *get skid up high
    *some sort of better/adjustable arms
    *SYE
    *Atlas
    *bling driveshafts
    *35s
    *cut rear fenders
    *cage
    *wheel piss out of it.
    Going for less down time, highway/backroad drivability, ease of repair, simplicity.
    The hardest trail it will see will be Clayton. I want to take it to Colorado, Moab, Fordyce, Rubicon, but seriously, Clayton probably has the hardest trails.
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
  6. #81
    Sand Man Shaggy's Avatar
    Dec 2007
    San Antonio or Victoria
    I have disconnects sitting in my shop ill let go for cheap
    Jonathan Tate
    361.676.6466
    2004 Jeep TJ
    1992 Jeep YJ
    2008 Jeep JKU
  7. #82
    Respek TdmayfieldIV's Avatar
    Sep 2009
    I wouldn't hesitate to drive it on the street with 37's.
    This is what I would do
    -superduty axles
    -Make some radius arms for the front
    -4 link rear with artec truss
    -comp cut with rear body guards
    -105 ish wheelbase
    -Detroits rear, Arb Front and 4.56's
    -Trailready or raceline beadlocks with 37" toyo's or Maxis trepadors
    -Fox 2" coilovers, You can find them used all day long on race-dezert
    -Air bumps
    -Most competitive rigs don't have a ton of up travel so that they can keep it low. Evan's jeep only has like 3 or 4 inches of up travel and gains all of his flex in droop. That's why a rear truss won't get in the way too much. Might have to re- locate the fuel tank.
    -Bling driveshafts
    -Flat belly skid, I'm sure there's some beat off jeep uhmw skid
    -Whatever gay ass t-case tate has
    -cage
    -tunes
    -fuzzy dice
    -keep the a/c
    -winch
    -wheel said piss
    But that's me and I like to make things hard on myself.
    F*ck off cj.
  8. #83
    Nov 2002
    Tx
    Don't forget the Wicked Wheel!
    BDR
  9. #84
    San Antonio, Tx
    Jk turn signals. Pulled the fenders back off to repaint black
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
  10. #85
    San Antonio, Tx
    I got some 35x12.5x15 KM2s. The front looks great and it only seems to rub on the sway bar. The rear armor panels are in SA and I am going to bring them back with me next week and get them on. Problem in the rear is that the tire is very close on the front side to the tub. For my trip in a few weeks, I probably need to just do a spacer lift and mayeb some new shoks. RE spacers and new shocks run $240 so not too bad.
    I still need to clean up the hood and paint it.
    I have the old 33s for sale if anyone needs a spare. I think Taylor has dibs on two of them.
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
  11. #86
    Jan 2006
    DAAAnngerrr Zone!
    That new windshield washer RestoMod ( Fred ) is Rice-A-Roni!!!
  12. #87
    San Antonio, Tx
    Got the rears on last week and 2" spacers today
    The front axle naturally moves over to the drivers side slightly. Is this easily fixed by drilling g new hole in lower bracket?
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
  13. #88
    Jan 2010
    I'd go adjustable track bar. If you go higher or lower later you can adjust it in or out instead of welding up holes and trying to drill them out straight every time.
  14. #89
    Dec 2007
    Drilling works but tends to oval out over time and require welding. I would go adjustable too
    Jonathan Tate
    361.676.6466
    2004 Jeep TJ
    1992 Jeep YJ
    2008 Jeep JKU
  15. #90
    San Antonio, Tx
    I would agree that an adjustable would be better
    Is the problem that you are more than likely not going to drill a perfect hole through both pieces, thus it will wallow out?
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
