Page 7 of 11 FirstFirst ... 3 4 5 6 7 8 9 10 11 LastLast
Results 91 to 105 of 162
Thread: JB's TJ
  1. #91
    Jan 2010
    That and if you start drilling holes in different places then your drag link and track bar won't be parallel and will cause bump steer. I'm assuming this thing still gets some street time so that would be no bueno.
  2. #92
    Sand Man Shaggy's Avatar
    Dec 2007
    San Antonio or Victoria
    Quote Originally Posted by JB View Post
    I would agree that an adjustable would be better
    Is the problem that you are more than likely not going to drill a perfect hole through both pieces, thus it will wallow out?
    This and your drill bit is still in the first hole while cutting the second one. The bits I use will cut the hole bigger if you move the slightest.
    Jonathan Tate
    361.676.6466
    2004 Jeep TJ
    1992 Jeep YJ
    2008 Jeep JKU
  3. #93
    lowballing someone
    Feb 2005
    Houstonish
    and it is a stress point in the front suspension. stock and factory ones oval out leading to death wobble and it is sometimes hard to determine where it is coming from
  4. #94
    Dec 2007
    any updates?
  5. #95
    ill be your pickup man
    San Antonio, Tx
    Not really.
    I have been driving it alot.
    Took all soft top bracketry off.
    Got the PSC sliders on.
    Fixed some minor stuff from Carnage Canyon.
    Traded for some half doors which I really like. They are also white, so its mismatched black white everywhere, kinda looks goofy.
    Also got the passenger side seat bracket move-back kit on yesterday.
    About to fix factory spare tire mount that cracked in hopes to make it hold the 35 for a few more trips.
    Put some fresh bump bump speakers in it today. About to load up the toolbox in prep for Shiloh.
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
  6. #96
    Dec 2007
    Where did you end up getting your fenders from?
    Jonathan Tate
    361.676.6466
    2004 Jeep TJ
    1992 Jeep YJ
    2008 Jeep JKU
  7. #97
    Jan 2010
    I like the fenders he chose, they look good. This jeep looks like a cop car almost with the black and white body panels.
  8. #98
    San Antonio, Tx
    Poison spyder
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
  9. #99
    Oct 2004
    Headed back to the Big D
    I think I have a bestop tire carrier for a TJ that I will let go for cheap if you are interested
    It bolts through the body to the roll cage on the top and the body mount on the bottom.
  10. #100
    San Antonio, Tx
    Axles
    Not ready just yet, but want to be on the look out. I have not searched for axles in close to 10 years. So many new options out there.
    Width.
    After wheeling it some, I really have no issue with the track width. It is nice fitting easily through trees. Would not want to go fullsize. From brief searching, looks like stock TJ is about 60" and a d60 is around 70". Would splitting that be reasonable?
    Just for reference, what are the off the shelf options? Currie, G2, Dynatrac? Could put together a Spyder9?
    Should I just be on the look out for a kp60? 10.25 for the rear to be different? My concern with narrowing an axle down is the pita of ordering a new shaft and not having readily availible spares.
    My dumb plan right now would be to keep it close to same height, still run good 35s, tummy tuck, long-arms, keep it fairly simple
    Out of curiosity, what does a TJ Rubicon front 44 go for used? Still have the idea of building 44s and keeping it on 35s.
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
  11. #101
    Jan 2010
    Waggy 44 and 9 inch, Locked rear, auburn limited slip front, 37s keep it light weight.
    Building from a custom housing gets real expensive real quick because you have to buy every piece and then you have to put it all together. You'd be time and money ahead to put axles in with chromos and disk brakes in the rear.
  12. #102
    I'd just buy a super 30 kit and super 44 kit with whatever locker you plan on running.
    The only real argument against the super XX stuff is if you did manage to break something won't be able to find replacements from the Slims of the world, but it is pretty relaxing to park it, drink, then order replacement parts on Monday. Its not like you are going to find replacement rubicon shafts out in the wild anyway.
  13. #103
    H-TOWN
    Lynda's front is 64" it's a little too narrow, tires rub the frame. I built the buggy to 65 or 66 I think.
    Scott, FTAC '99
    '89 "CJ-7" - Her trail rig
    scott.schubring@williams.com
  14. #104
    Big Baller 85cj7's Avatar
    Sep 2006
    The Big 'D'
    Quote Originally Posted by redcagepatrol View Post
    My front is 63.5WMS and the rear is 62" WMS. If I had to do it again I would go an inch or two wider. Maybe 66"WMS in front and 64.5"WMS in rear.
    If you're gonna keep it on 33"s then I agree with Flem. Polish those turds and be done with them. Otherwise I would build ruffstuff 609s front and rear and dump the coin into what matters. Then never worry about them again. (Sparlings d-44 and 9" suggestion is not bad either)
    Scott,
    Is that a yj frame? Aren't they a bit wider then a CJ? I don't have any frame clearance problems on mine.
    i dont speak australian.
    seacrest, you are my hero!
  15. #105
    H-TOWN
    yes - YJ frame
    Scott, FTAC '99
