Page 8 of 11 FirstFirst ... 4 5 6 7 8 9 10 11 LastLast
Results 106 to 120 of 162
Thread: JB's TJ
  1. #106
    Jun 2005
    and a tj frame is even wider than yalls, especially in the back. id say at least 2 inches wider per side. set it up with a neutral wheel and then u can adjust it easier with a different backspacing if u dont like.
  2. #107
    ill be your pickup man
    San Antonio, Tx
    The PSC rear armor I have is of course nice and flat on the inside but the body of the jeep is no longer perfectly straight. It has a few low spots which allow mud and water to be trapped. I am going to pull them off and work those areas a little more but what else can I do to seal it off?
    Black caulking from Home Dept? Not sure how much body /armor would move.
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
  3. #108
    lowballing someone
    Feb 2005
    Houstonish
    Weld to body.
  4. #109
    Jun 2005
    3m Seam sealer
  5. #110
    H-TOWN
    weld it.
    Scott, FTAC '99
    '89 "CJ-7" - Her trail rig
    scott.schubring@williams.com
  6. #111
    San Antonio, Tx
    The Jeep did great at Clayton. I put a hole through the oil pan on Walk in the Park and bent the exhaust on Green Mamba. All in all, pretty damn good.
    Pretty overwhelming options to go from here. Longarms with coils? Stay low and on short arms? Stretch? **** is very expensive
    The wheelbase really did not bother me, other than the rear departure angle. Height was also decent, though the stock skid is very low. 30/44 held up fine. Still thinking if I found a bolt in Rubicon 44 that was not absurdly priced, I would do it.
    Tummy tuck skids , maybe a real 2-3" spring, better shocks, adjustable short arms, lockers and shafts. This option is very minimal fab, less down time, more wheeling time.
    One other thing I need to do is research better alternators. BDR said there is a 120 amp Ultima at Oriellys. The one on there now does not like winching. Might also have an Optima slowly dying.
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
  7. #112
    San Antonio, Tx
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
  8. #113
    Big Baller 85cj7's Avatar
    Sep 2006
    The Big 'D'
    It says the 23 spline input is for a manual trans only. Isn't yours an auto?
    Sounds reasonably priced to me.
    i dont speak australian.
    seacrest, you are my hero!
  9. #114
    Sand Man Shaggy's Avatar
    Dec 2007
    San Antonio or Victoria
    how used it is? They have very little fluid space in them and will burn up bearings easily. I toasted mine. I am going to rebuild it and stick it in Jason's jeep. I wouldn't spend that much myself unless it was pretty much brand new. A used Atlas would be way way better. I would imagine you end up with an atlas in the long run anyhow. Can't do a front dig with a teralow case either.
    Jonathan Tate
    361.676.6466
    2004 Jeep TJ
    1992 Jeep YJ
    2008 Jeep JKU
  10. #115
    San Antonio, Tx
    I think it depends on the input shaft length. Teraflex only calling them long(manual) or short(auto). Need To research more.
    Looks like stock Rubicon cases have 4:1 and fixed yoke for around same price
    Are used Atlass that common? I don't want to sit around waiting
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
  11. #116
    Jun 2005
    Krazy Krosby
    A couple atlas's a week pop up on pirate. The problem is finding the correct side drop, input shaft and the ratio you want. They are generally in the 1800 to 2500 range.
    -Karl
    1965 Chevelle
    1975 Corvette
  12. #117
    Respek TdmayfieldIV's Avatar
    Sep 2009
    Atlases are for the weak.
    F*ck off cj.
  13. #118
    Jun 2005
    Krazy Krosby
    Quote Originally Posted by TdmayfieldIV View Post
    Yeah, that's why I sold you my doubler and bought an atlas.
    -Karl
    1965 Chevelle
    1975 Corvette
  14. #119
    Jan 2010
    That was to sabotage tommy. Like selling blankets to the Indians.
  15. #120
    San Antonio, Tx
    Think I'm going to look for a rubicon case for around $1k. No doubt an Atlas is nice, but I'd spend 3 times as much for a new one. I could buy another Honda fourtrax with extra 2k.
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
