Some of yall have seen my rear mounted radiator that is currently at a 45 degreeish angle blocking the back window. I mounted it up there to allow for air flow and also to mount the propane tanks underneath.
I'll be doing a real roll bar and some slanted pieces going to the rear frame rails within the next month in order to clean up the bed and make it more streetable so was wondering what yalls input is on keeping the radiator up mounted to the roll bar or moving it straight up and down behind the cab.
Pro's would be if it was behind the cab under the window I would be able to use the rear view mirror but will that decrease airflow too much for street driving? I have two electric fans on the radiator that cool too much as it is while off roading.
