Results 1 to 3 of 3
Thread: 78-79 bronco power steering box or70's f series
Hybrid View
    im converting my 66 u13 bronco to power steering and i need a box from a 2nd gen bronco or f series 4x4 from the mid to late 70's which should all be the same as the 78-79 bronco. i combine that with an 80's box internals and according to the internet it is a fastastic upgrade. so does anyone have one laying around they want to let go of? i will gladly take lines as well if they are good.
    im also looking for chevy or jeep fsj small bearing spindles for a d44 that are the 6 bolt and caliper brackets and calipers, ford rotors and hubs that are 5x5.5 from a 4x4 from the 70's all the way including ttb stuff to convert to disc brakes.
    thanks guys
    I have a tapped box that I'm getting rid of to do full hydro....also have the pressure line to connect it to a psc pump which I had to have custom made.
    F*ck off cj.
    this is for a restoration not a wheeler so I'm more looking for a stock box than a tapped one. everything needs to look factory
