well i'll try that, hopefully i'll be able to get most of the stuff done this week,
i still need tie rods and a couple other small things, but most of that i can get at work, so hopefully i'll have it outta the garage soon
Mine was welded with 7018 rods with a DC machine by a professional welder. Not calling myself a professional, but I have a few of them around my shop. It came apart and ate half the teeth off one side gear, and all the teeth off the other. But it hardly damaged the spiders and didn't do anything to the ring and pinion. Now it is welded side gears to spider gears with much more weld, side gears to carrier, and spider gears to carrier. Used 16 rods. I'm not saying that it won't last with it just welded side gear to spider gear, but mine didn't.
Hey check this out, I think they make them specifically for what you guys are trying to do...
Boats and hoes
well, not quite specifically, i was trying to do it for under $20, but if this don't work, then i'll be using one of those
1
2
3
how does this shackle angle look?
I think you'll be ok with that angle. It could probably stand to be steeper, but this way you won't have to worry about inverting it under full droop.
I'd turn the bolts in your shackle around, however. You probably won't hit anything with them, but I'd put the exposed threads inboard just to be safe. I think it looks cleaner, too.
Nice work, keep it up!
thanks, yea i have a lot of odds and ends to finish up, i'm goin to clean those shackles up and grind the ends smooth, i'm gettin my brake lines finished thursday and workin on steering this weekend, so hopefully it'll be done soon
Those ThornTurds just woint die will they?
lookin good! looking forward to seeing it in action
Cody Ainsworth || FTAC '05 || '91 YJ
4.0, SOA, 36" IROKs, D30/F8.8, LockRight/Detroit, 4.56s, Hydro-Assist, fullcage, TJ flares, blah blah blah.
www.Jeeps-Offroad.com || Pictures
this is going to be an interesting spring break (snap, boom,crack) trip...
Scott, FTAC '99
'89 "CJ-7" - Her trail rig
scott.schubring@williams.com
Scott!!! Don't go and jynx the whole thing before we even leave!
i'll possibly be able to hear the snap of toyota parts all the way in Angel Fire, , but unfortunately I won't be in Cruces w/ ya'll, i'm goin snow skiing, but on the positive side my "wife" will have spring breaks and summers off after we graduate, so we will have time to go then if i can get away
I think I'll be able to hear the moans of a toyota forced to wear Nissan clothes all the way in Hawaii... I'll keep my ears open.
Doug
