Results 1 to 9 of 9
Thread: Ford 9in
    ill be your pickup man
    San Antonio, Tx
    Ford 9in
    Ford 9in. out of a 79 Bronco, 31 spline, 3.55 gears or so, nothing else........$100
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
    Shaggy
    so i guess you decided to keep the 8.8 ... does it have shafts?
    San Antonio, Tx
    yeah at least for now, I need money. Yes, it has shafts, no brakes though
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
    Shaggy
    i'd think about getting it for parts but i already learned that the diameter of the shafts on the '78 & '79 are different than other years... hence it wouldnt do me no good
    Dallas, TX
    couldn't you transfer the brakes and 3rd member from yours and use his housing and shafts?
    Shaggy
    probably
    Krawler68
    all Ford 31 spline 9" shafts were the same diameter...do you mean they were a different length?
    Doug
    I think he means the part where the wheel bearing rides. Probably different since ford used a dozen or so bearing configurations, big bearing, medium, small, 80's big bearing, 8.8 bearing,etc.
    Shaggy
    yup flem is right
