Does any one know of a good place to get perforated steel in with BCS or DFW?? need a cheap piece with 1/8 " holes and about 1/8" thick about 2' by 4'.
are you talking about expanded steal??? if not then i am not sure what you are tlaking anout
Steven W
02 Dodge 2500
there's a pretty good metal shop out on 21, I just forget the name off hand, Robert should know, it's where his angle iron for rocker panels came from
there is Brian Iron & Steal....Mack Bolt & Steal...there are several...
Steven W
02 Dodge 2500
well, I think that is what he was looking for.....
Mack bolt and steel is open on Saturdays, and was my steel supplier of choice when I lived in BCS, up here in DFW Garland steel is the place to go. Their up front prices suck, but they have a ton of secondary steel, which is steel with some sort of defect. Usually its a split down the end or a kink or bend in the tubing.
I built my shop press out of 20 feet of 1x4x3/16" secondary steel and it cost around 40 bucks
and looks like you blew your nose on it...
his welds with the arc welder look better then some of yours with a mig welder....
Steven W
02 Dodge 2500
you can try metal supermarkets I think it is in irving
www.metalsupermarkets.com they have a sh itload of stuff and I think they can pretty much get anything, probably isn't the cheapest though.
Boats and hoes
If you're buying in BCS, I recommend Mack. They're good folks. i've never gone to the other place. never felt like I needed to. One thing to note though about Mack B&S, they're only open until 2PM on Saturdays. So keep that in mind if you're going to be binging Friday night.
~dso
