what should i use for a t-case skid plate, i'm redoin the piece of crap someone riged up under my pile and i'm goin to make my own, what size sheet metal should i get to make it out of?
heat and bend some 3/8" flat plate. Jason did that and it came out pretty good + only 3/8" think.
it might have been 1/2", can't remember
Scott, FTAC '99
'89 "CJ-7" - Her trail rig
scott.schubring@williams.com
USe some of that plastic **** that weighs nothin'... It's like 10x lighter than 3/8" plate steel...
Doug
are you for real - what is it? I want someOriginally posted by Krawler68
Doug
Scott, FTAC '99
The stuff the make cutting boards out of.
1/2"? Was he building a tank? Expecting land mines?
http://www.indplastic.com/index.cfm?...875&product=38
here is one option...Delrin. Kind of more brittle than the following two options... you really should tuck EVERYTHING in the frame rails before you go this route...it would be REALLY dumb to try and mount your t-case to .5" plastic.
I think this stuff may be anywhere from 1/2 the weight to 5x lighter... my first statement was a little optimistic.
Here are two other options.
UHMW- not much info, but seemingly a tad bit softer than HDPE, which is more like cutting board material.
HDPE- http://www.plasticsusa.com/hdpe.html
These substances can be ironed to get rid of gouging made by rocks.... the only condition is that as heat is applied to these products they become VERY weak... at 180* you should be able to do a 90* bend with your gloved hands... hence it is imperative you keep ehaust away from these skids, or else heavily insulate your exhaust.
Doug
plastic sounds like a bad idea - too much to worry about with the heat and getting stuck on rocks. The weight is down low anyways, not a big deal to use steel
Scott, FTAC '99
It's actually a luricated plastic at the molecular level, and if insulated properly works pretty badass... seen several people use it, and they just drag right over stuff... they like it alot... any weight is bad weight...
Doug
He's building a real jeep, they don't use ****ty little Z71 plastic skid plates. I'd build a beefy tranny mount then the skid plate out of 3/16" and use some angle iron or whatever you have laying around for bracing.
Ryan continue on in the stoneage... you are a dumbass if you think there isn't room for advanced plastics in the rock crawling world. The purpose of a skidplate is not to be heavy...its purpose is to deflect rocks away from expensive and delicate driveline parts and slide you over boulders... high impact platics in .5" thick applications are Exceptional for this... not to mention well used and trail proven. If you ever try to climb an extremely vertical climb you'll find out the advantages of light weight and try to lose weight everywhere you can. Every pound counts. EVERY POUND!!!
Doug
as much fun as it would be to say i had a milk jub skid plate, i'm goin to have to go w/ steel because of the price issue and this ain't no comp rig, so i guess i'll deal w/ extra weight, but i think the 3/8 th's flat plate might be the best choice as of now
I have a sheet metal brake biotch.
the plastic would only be 200 bucks... and you don't need the sheetmetal brake...just a hairdryer...
Doug
Metal is a few cents per pound. Since you've got all this money coming out of your ass, why haven't you bought that 60 you keep wanting? And if you're gonna talk **** about my weight, you could say something about maybe bobbing it, or removing the AC system, or the passenger seat, or a number of other things that actually make a difference. But $200 to lose 30 pounds, I could do that much by just not eating, and taking my boots off.
Hmmm... because I've spent more than a D60 on beefing my D44...
I have spent enough to build a pair of 60's on my 44... it's the nature of the beast I already had it ready to go, and so I kept dumping money in it.
As for having money coming out of my ass... 200 bucks isn't that much money. Find me a D60 for less than 800 and I'll buy it.
I wasn't talking **** about YOUR weight, but weight in general... and it's not 30 pounds but more like 100 pounds if you run a full skid plate...
Doug
