Thought I might actually be done fixing the EB in time for TCC. After working on the EB for 2 days solid this last weekend I thought I had fixed my problems... seem like I may have a warped head now though... I installed new head gaskets and seem to still have a coolant leak out the back of the intake manifold, and a possible oil leak. The water temp gauge still isn't reading correctly, and after a 45 minute drive yesterday it was running a little hot (boiling radiator...just not enough pressure to pop my cap). I am also getting HELLA knocking from it around 2200-3000 RPMs... any takers? Anybody have a nice 302 long block they want to get rid of? I'm not exactly excited about dumping MORE money into this already tired 302.
On the plus side... after replacing the head gasket I seem to have solved several of the problems I had in llano... no serious oil leaks... doesn't start stuttering and backfiring under load in 4th gear. It actually seems to run well except for the temperature thing, the frothy coolant/oil mixture on my oil cap, and a lot of valve noise.
Doug
