Results 1 to 13 of 13
Thread: Call Me Crazy
    San Antonio
    Call Me Crazy
    Would it be feasible to cut off the rear of one's leafd springs just behind the axle and add two more control arms. Then use the two fronts of the old springs as control arms and put coils on top of the axle where the leaf springs bolt on?
    fbronco86
    In the words of Jimmy "that sounds like a good idea"
    Brazos County
    While technically you could, i don't think thats the issue. WHY would you want to? it would basically be ****** rigged booty fab seems to me. the spring effect from the leafs would still be there, and they most likely would not be rigid enough for control. also the coils would be wierd at contact point and shorter than need be. just use coils and the control arms, plus two more control arms with no leafs, how much can it possibly add?
    Seth Stewart '04
    2000 Suburban DD
    1998 GMC pickup - sold
    1975 Scout - TBD
    1976 Scout - parts truck
    1972 IH 1310 dually - TBD
    196? Scout 800 - 302 roller
    Brazos County
    oh and by the way -- you are crazy.
    Seth Stewart '04
    2000 Suburban DD
    1975 Scout - TBD
    I agree with seth...no rigidity.... might get some kinda funky axle wrap
    plus...when a leaf is compressed, it goes towards the shackle. So even when sitting it would be putting a force on the other 2 solid links that you wouldn't normally have, not to mention if you hit a bump...
    what is your reason for this?? cheap??? easy??? sounds canadian to me!!!
    1988 Blazer...RIP
    Dallas, TX
    you're crazy
    [rainman voice] cra crazy...definatly crazy [/rainman voice]
    Steven W
    02 Dodge 2500
    San Antonio
    Maybe I should swap the front with 5" alcans and then try to find some coils to match the lift of the front.
    That way I can drop the moeny for front springs and do the swap NOW.
    Ya think?
    Brazos County
    do you have to have new springs to do the front? just do it step by step - i thought you could...
    Seth Stewart '04
    2000 Suburban DD
    1975 Scout - TBD
    Krawler68
    It won't work like everyone has said... KISS
    Doug
    Dallas, TX
    Ya think?
    what kind of coils - I know my buddy that works at Car Quest here got some Aerostar coils for pretty cheap through work
    HUH YOU HAY......YOU GAY.........
    Steven W
    02 Dodge 2500
    bigFAWKINranger
    or just get an AWD aerostar and wheel it.
