Results 1 to 13 of 13
Thread: gear box brace
    aggielr
    gear box brace
    this one cost a lot less than the one from the magazine, but took awhile to make, didn't have much of a template to work with
    aggielr
    2
    aggielr
    3
    how does it fit on there landon?
    Steven W
    02 Dodge 2500
    aggielr
    painted it last night and bolted it on, works great
    aggielr
    here's some of it mounted
    aggielr
    2
    how is it braced more then it was before....looks like you made a whole new mounting bracket so you could remount it somewhere thats not factory....
    Steven W
    02 Dodge 2500
    aggielr
    on the '79, it was 2 pieces of stamped steel bolted together and to the frame, the gear box would swing about 3 or 4 inches back and forth w/ the bigger tires on it, wasn't very sturdy, but w/ this one, its much more solid
    this is similiar to what i was shootin for, but this one cost $90
    looks like you did a good job...how long did it take you to make it and was it worth saving the $90(- parts) to do it yourself?
    Steven W
    02 Dodge 2500
    aggielr
    well i was able to use someone else's drill press, so counting that, about 4 hours total, and yea, it was worth it, mostly cause i can say i did it
    mine also drops down about 1" so it makes my drag link almost parallel to the tie rod
    Oct 2002
    Poth, Tx
    You thinkin of running a brace from the box by the pitman arm to the frame rail on the other side too? I think those work well. That's all I have on mine. Before it, most of the play in my steering was actually coming from the box moving.
    aggielr
    yea, thought about that too, but this was cooler, i'll probably end up havin to use one of those if i lock the front, but right now its still open, so this sould be ok
