only can afford one at a time right now, which should i do first?
fuel injection
lower gears
Stop workin on it and just get it runnin!!
come on man, is it even a question? that t150 sucks. Worst crawl ratio ever to come out of a jeep vehicle. If you count the torque convertor, a 2wd postal jeep is better off from the factory.
fuel injection best mod ever you can learn to drive with the gears
what gears and tire size are you running now? i'm too lazy to look it up. also, i'll combine what ryan and josh said...fuel injection is the best thing ever, but it depends on how bad you are on angles right now.
gears and a motrocraft 2100 or QJet w/ adjustable regulator. carbs are cheap and can work at angles. when you go to crawling just turn down the regulator to keep it from loading up.
so whens the first trip??? cause i'm goin damnit, ****ty gears and carbed first, i'm just wonderin which one i should start stock pilin parts for first, but since i already have a sm465/bellhousing/and other crap, i'll just have to buy the high dollar adapterStop workin on it and just get it runnin!!
