View Poll Results: fuel injection or lower gears?
Voters
61. You may not vote on this poll
  • fuel injection
    5 8.20%
  • lower gears
    3 4.92%
  • Stop workin on it and just get it runnin!!
    53 86.89%
Results 1 to 6 of 6
Thread: fuel injection or lower gears?
    aggielr
    only can afford one at a time right now, which should i do first?
    come on man, is it even a question? that t150 sucks. Worst crawl ratio ever to come out of a jeep vehicle. If you count the torque convertor, a 2wd postal jeep is better off from the factory.
    Tariqui
    fuel injection best mod ever you can learn to drive with the gears
    BigRedFord04
    what gears and tire size are you running now? i'm too lazy to look it up. also, i'll combine what ryan and josh said...fuel injection is the best thing ever, but it depends on how bad you are on angles right now.
    gears and a motrocraft 2100 or QJet w/ adjustable regulator. carbs are cheap and can work at angles. when you go to crawling just turn down the regulator to keep it from loading up.
    aggielr
    so whens the first trip??? cause i'm goin damnit, ****ty gears and carbed first, i'm just wonderin which one i should start stock pilin parts for first, but since i already have a sm465/bellhousing/and other crap, i'll just have to buy the high dollar adapter
