No progress...
TJ Dana 30 housing
I just pulled my TJ Dana 30 housing out from under the Jeep. It is just the housing with knuckles. The ball joints are good, all the bearings and seals are good to go, the bearing caps are bolted back into it, and the cover is on it with all the diff cover bolts. I stuffed some shop rags into the tubes and the pinion so water/bugs won't get into it.
I don't really know what it's worth, sooo...
$50 OBO
- You may not post replies
- You may not edit your posts
Forum Rules
