Np 231 t-case
I need a new t-case my shell is destroyed so I only need the case but I will take anything you can sell with in reason.
No progress...
Which half of the case is destroyed?
Blake got a cheap NP231 for it's internals, so he has an empty case sitting in our scrap bin right now.
The rear half is cracked from the top all the way around the side and to the bottom. The bottom u joint went out on the highway and the drive shaft hit alot of solid metal.
Sweet let me know if he wants anything for it. I'll let my sugar mama know and see if I can work a later shift at work to make some more scratch.
- You may not post replies
- You may not edit your posts
Forum Rules
