For about 3.5 years now my water gauge has been reading higher than it did when I first got the truck. Not only does it read higher, but it gets higher and lower with any change in conditions. It never used to move around, and all other cars I have driven in have guages that stay in one spot no matter what condition they are in.
I have 2 electric fans that blow a lot of air.
Thermostat - 195 deg (correct, new)
Radiator Cap = 13 psi (correct)
No leaks
Full of water
New sending unit
Slightly corroded wire connecting to sending unit very loosely.
Did not lower radiator when put on body lift which puts it 3" higher relative to the motor as was before. Did not notice chang in guage until 6 months after body lift.
Symptoms -
Runs "hotter" on the highway (higher RPMs)
Runs "hotter" on hot days
Passenger side fan blows barely warm air, drivers side blows hot air. Radiator possible clogged (~4 years old) Water comes in top of passenger side, leaves bottom of drivers side.
Please help. I have been dealing with this problem for 4 years now. No one has been able to diagnose it. I don't know if it is the gauge or if it is actually running warm. I put an aftermarket gauge in the upper radiator hose and it reads 230 to 240 which seems pretty hot, although water does not boil over into the reservoir at this "temp". The factory gauge reads close to the top of normal where is used to read about 1/3 of the way up from the bottom of normal.
Heater blows air over 200 degrees using turkey thermometer in the vent. Is this normal??
