try brazos valley out on 2818, I know he can balance it as well. I don't remember it being that much when I was building the scout.
Boats and hoes
Not to hijack, but I need my rear shaft shortened, about how much would it be at BVD? What do ya'll mean by retubing?
92 YJ
04 F-150 4x4
11 F-250 4x4
It means saving the old yokes and installing new tube between them.Originally posted by JBrown89
They reuse your old flanges and install a new driveshaft tube to connect them. If you just need your shortened then they can just cut and re-weld one end and you should be able to get off a little cheaper.
damit Grayson...
i took it to bvd. they quoted me $110. plus like 20 for a computer spin balance. i should get it back tomorrow afternoon.
I had mine shortened and the CV greased up for $46. If they shortened it and rebuilt the CV, it was $105. Not bad.
92 YJ
04 F-150 4x4
11 F-250 4x4
Not to beat a dead horse, but did you get a shaft retubed Dan? I ask because I need my rear shaft lengthened and I'm trying to figure out where the best (cheapest) place would be to take it. I figure I come up to CS anyway, I can bring a shaft up with me to get cheaper work done to it.
yeah I did. now it is bright blue too! I think the total came to around $150, with the computer spin balance and they replaced at least one of the u-joints too. I got it back in a day or two as well. I would go to them again if I needed anything else.
i dunno how close you come to Seguin when you come up to CS, but i've had mine retubed at Seguin Alternator and Drivetrain twice, and shortened there when i put the 60 in the back....pretty good job as far as i can tell, and its shiny when you get it back. if you call ahead of time they'll do it while you wait. it was only like $45 to get it retubed and like $75 when they shortened it b.c. i had them put the bigger yoke on it to fit the 60.
After the July 4th alto trip, I am forced to do some work on the rear drive shaft. I was thinking of having BVD or Bryan Drivetrain build me one. How can I go about getting the correct measurements for them to do it, or will it be best to just take the truck there and let them do it. Either way, I will wait till the 60/70 get put in, and may have them make a front for it also.
if your not gonna have it done in waco. id say order one from longview driveshaft. ive had one of theres and one from bvd and i liked longviews much better.
non highway use, make your own. take your yokes to the steel yard and find a piece of pipe that works. Take a measurement at ride height and allow about 2" of compression
