step 1: drag axle into the kitchenOriginally posted by bburris
I also need to figure out how to pull a real front axle apart now... The hubs and crap look confusing now that I'm used to unit bearings.
Yeah, then I'll need to locate an abandoned fork, a broken screwdriver, and something to pound on them with.
Ahhh but first you should check for the bearing cooler and make sure its not still hooked up..
i made/machined high steer arms for Xtreme a couple months back, we could do it...if nothing else we could drill and tap the knuckles if you need it.
I'll take you up on the mill/drill/tap thing...
I'll take you up on that as well.
Well here are some progress pics. I haven't had time to get too much done but it is starting to take shape. Also does anybody have a pattern as far as how to mill done the passenger arm and tap for high steer?
I am going to cut it down some more and i will box it in and mount my upper control arm on it.
This is Ben by the way.
