Results 1 to 9 of 9
Thread: Pro-Rock Comp in Farmington
    H-TOWN
    Troy and Doug didn't do too well.
    Had a flop on day 1,
    had a full roll on day 2 (driver, top, passenger)
    had another flop on day 2, he called it a day after the second roll.
    one good thing - the cage held up good!!!
    they beat one person! Troy said that Doug would no longer be spotting for him...
    Troy thinks that he might have bent some pushrods and is going to try and get that fixed before the Comp in Nevada.
    UPDATE: he just called - flattened a lobe on the cam. Hope he gets that fixed
    That's all I know - Hope we do better in Cougar Buttes, CA
    Scott, FTAC '99
    '89 "CJ-7" - Her trail rig
    scott.schubring@williams.com
    Dallas, TX
    ...sooo, he needs a new spotter?
    I've got a boring summer ahead of me...
    H-TOWN
    I'm going to try pretty hard to make all of the events. I think that he only has two more this season, and I will be at the one this weekend
    Scott, FTAC '99
    Shaggy
    as much as you see hal on his lid with doug spotting him you think troy would have gotten the idea that it wasnt totally hal's fault
    Hazaa Fredo's Avatar
    flat cam lobe??? it must have done it fast because it wasn't acting like that when it was at my place.
    Dallas, TX
    Hal and Doug's problem was due to the vehicle they were in. Doug couldn't really do much for spotting, as was probably apparent when I was trying to spot for Hal in Katemcy. The ZJ just kind of drives where it drives, Hal usually tries to keep it between the cones... Doug just makes sure he knows where they are before he floors it.
    AgDieseler
    How exactly does one flatten a cam lobe? It's a hardened piece of cast iron, so it's very wear resistant. I can only guess that a collapsed lifter would do something like that.
    well, i know big block chevy's are notorious for flattening cam lobes. If the hardening process on the cam is done incorrectly or the cam and lifters never develop a correct wear pattern, it can happen. Ask grayson, he knows all about flattening a lobe on a cam.
    Oct 2002
    Poth, Tx
    I got a flat one in my previous jeep motor. It happened after the lifter quit pumping up and I didn't feel like fixing it.
