I went with a Krebs-like title to draw attention...
I got the floor cut out of the donor subbie today and we were able to finagle the engine/tranny/t-case out without unbolting them from each other. I suspected that there was something wrong with the distibutor because it felt loose. When we got it all out I saw that the aluminum part where it attaches to the block was broken all the way around so the top part spins freely... Not good. I guess I'll look on ebay for one from the same time frame. Are they somewhat universal?
The other problem is the tranny. There is a big crack from the top bolt to the second bolt down and a chunk appears to be missing. Very bad. I can't use this thing in that condition because I know how I drive... Would you guys suggest finding a 700R4 and one of the more common TBI computers and not worrying about all the problems I may encounter with the 4L60E swap, or should I look for a new 4L60E case and try to go through with it for a little bling factor? I've been reading a lot about the 4L60E and it doesn't seem like it'll ba that bad, especially since I was able to save all of the sub's harness to reuse whatever I need. I'm just not sure that it's worth the extra hassle and cost if I could just find a 700R4 and bolt that in.
The outputs will be the same, so I can still use the NP241 and get the super shorty SYE like I planned... The tranny is all I have to worry about before I can start the manual labor part of getting it all shoe-horned into the Jeep.
