Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Thread: spare 35-38s and some leaves
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    i am now in need of two spare tires for the bronco, i need two of them cause i have two different lug patterns. i am wanting some spares around 35 in or above for a 15 in rim or one that is a 16 in rim. as long as they hold air they should be fine.
    i also need some stock for 3 in wide fullsize leaves or add a leafs for the bronco since it sits ass low by about 2 in. any help would be great.
    kevin
    Aug 2002
    have Coop's bfgs mounted and stock a fridge and I'll give you 4
    Dallas, TX
    I have a big azz 36-38" Ground Hawg that I've been using as a spare that I can part with. I think it's a 38.5, but it measures about 36" tall.
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    alright that would be great.
    SteveRanger
    I have 4 33 12.50 16 pro comp m/t you can have.
    Aug 2002
    do those have any tread? Rims are cheaper than rubber...
    SteveRanger
    they have a little. what lug pattern are you looking for?
    Aug 2002
    chevy/toyota 6-lug
    Registered william_ace's Avatar
    Feb 2004
    College Station, TX
    i have some overload springs from a one ton, i doubt that will help though.
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    no i need some regular leaves i thinkthe overloads would be to stiff. might just run a block like a 2 in or 2.5. since i am running 38's i would like to keep the spares above 35 in thanks though steveranger
    Violentv8toy
    i'll sell you my 38x13x16s for 50 bux.
    Dallas, TX
    My tire is a Monster Mudder, my bad. It's at the shop so let me know when you might be passing through nearby or I'll bring it up to CS when I take all this Suburban stuff up there to collect from my debtors.
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    i am going to be going back up to c.s the 20th annd may be stoppng corpus, if not my dad is bringin the bronco a couple weeksafter that well figure something out.
    Aug 2002
    I have some tahoe leaves that might work for you...2 3/4" wide?
  15. #15
    Shaggy
    i have all the leaves you could ever want... i also have a set of 35's... well not really a set... i got 3 worn out mud kings... one bfg mt that is in pretty good condition and one brand spankin new bfg km... all fit 15" rim... i only one 5on5.5 rim though the other 4 are 5on4.5
