Results 1 to 10 of 10
Thread: TPI problems
    aggiemudman
    Guest
    TPI problems
    well along with the recently installed tpi of course it couldnt run flawlessly. ive driven it since tues. and fri. night i pulled into the bank parking lot and it died. It turns over but will not start. ive tried the coil and the module in the distributor. im all out of ideas because its not setting any trouble codes. any help would be appreciated.
    is it sparking? are the injectors firing? is the fuel pump working? theres a lot of possibilites, but I'd check that and then start tracing wires.
    aggiemudman
    Guest
    fuel pump runs, NO SPARK! not sure how to check injectors. all wires are ok and connections are secure.
    aggiemudman
    Guest
    tried replacing coil and the module in the dist....still nothing. just crankin no firin
    you can stick a test light in the injector plug and if it lights up then its firing, but the won't be if the distributor pickup isn't talking to the ecm
    sounds like wiring problems
    aggiemudman
    Guest
    Figured it out. Had a bad distributor. The magnets were cracked and shaft was bent a little. Just finished it up and the beast runs.
    Registered william_ace's Avatar
    Feb 2004
    College Station, TX
    what makes the components of the distributor go bad?
    fbronco86
    Guest
    Quote Originally Posted by william_ace
    kinda sounds like someone dropped it to me.
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    the easiest way to check and see if the injectors are firing is listen to them with a stethescope or put a screwdriver against them and put your ear to the handle. if you dont hear them clicking, then tap on them pretty hard to see if they are stuck. if that doesnt work, then you need to check the electrical signal with a noid light.
    aggiemudman
    Guest
    the magnets inside were just about to come apart. there were like 5 cracks and the shaft was burned pretty bad. But no i didnt drop it
