wiring problem
should a test light light up when i touch it to the signal side of the coil when it is trying to start?
just put your finger on it while someone cranks...you'll know if it works REAL quick
sure, i'll get right on that, i just need to know how much voltage is sent to the coil from the ignition control module and does any power get sent from the icm to the dist.
- You may not post replies
- You may not edit your posts
Forum Rules
