Results 1 to 5 of 5
Thread: 8 lug rims
    aggielr
    8 lug rims
    preferably 15, but 16.5 is cool too, something thats ugly, don't want to spend much, and 8" wide, w/ as much backspacing as possible, but whatever u got, let me know
    hey landon....you do know that if you get 15's you will have to modify the front axle.....dieslefag can tell you how to do it....
    Steven W
    02 Dodge 2500
    I think its just a little grinding.
    AgDieseler
    Thumbs up
    It's a little bit of grinding if you have 3.5" of less backspacing. The max you can reasonbly use is about 5", and to get those to fit is a much bigger job. If it is a D44 or 10 bolt, then you can keep the 8 lug hub and swap to 1/2 ton brakes, then a 15" rim will clear no problem.
    aggielr
    either way, i still need the rims
