to be installed in my new driveway... sooner or later.
sweet, how much did that set you back?
this is my plan for my rear end
landon found this on pirate awhile back amc 20 disk break conversion
sami front rotors and 300 zx calipers, bolts right up and still has a parking break
~~$100-150 in parts and thats all new
I've got zuki fronts on my cj, but the piston on the nissan caliper is tiny and I've heard its pretty ****ty with big tires.
I was thinking about some 8.8 calipers or grandcherokee/tj rear calipers. They both use a rotor with the same thickness. But I'm planning on a t-case parking brake. I've heard some isuzu's use a non vented rotor like that and have a parking brake
hey where did you get those?? Do they have anything for 14 bolts?
Kit - $280Originally Posted by J Cooper
SS lines from hard lines to caliper (you need them) - $50/pr
ouch! loaded calliper set from O'Reilly's - $250/pr, but they're from an '85 Cadillac El Dorado Rear W/Emergency Brake including all brackets and hardware.
http://www.tsmmfg.com/Rear_Disc_Brake_Kits.htmOriginally Posted by texasxj
and
yes
