Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 46
Thread: SAS Pics
    BigRedFord04
    SAS Pics
    I just have the 1st roll developed so far, finished product and testing pics will be up soon.
    ...and the transformation begins...
    BigRedFord04
    the TTB starts to go away
    BigRedFord04
    and its off!!
    BigRedFord04
    nekkidness!
    BigRedFord04
    still workin, late into the nite
    BigRedFord04
    ...the penis ring just above his hand is where the driveshaft rubbed the exhaust occassionally
    BigRedFord04
    rear axle (almost) out
    BigRedFord04
    4 tires replaced w/ 4 jackstands
    BigRedFord04
    (the next day)
    shackle flip complete
    *the pile of crap in the background is the TTB
    BigRedFord04
    our workplace
    BigRedFord04
    closeup of the new coils next to the old
    BigRedFord04
    nix still pretending to work...4" blocks installed w/ re-geared 8.8" and RS5012s.
    BigRedFord04
    last one for now...nix using the "specialty" tool to finish removing the steering, an 1 7/8" wrench lovingly known as "the big tool" or "thaxton" for short
    ill be your pickup man
    San Antonio, Tx
    What kind of setup are you going for up front? 3link? 4link?
    I am ready to start tearing mine apart, just need to get it up to CS somehow
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
  15. #15
    BigRedFord04
    i dont know what kinda "link" it is...factory radius arms from a `79 bronco w/ 7 degree C-Bushings on the axle...2 on each side...4 total?? i used the `95 radius arm mounts but moved them back 4" b.c. the older arms are longer. nix was kind enough to shave the body mount so they'd fit correctly and then the radius arm and body mount were welded together. I'll add a pic of that to the roll i need to finish for developing.
