Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 46
Thread: SAS Pics
  1. #16
    ill be your pickup man
    San Antonio, Tx
    I think that is considered a 3 link. That is most likely what I will do just b/c is seems to be very simple. Are you going to have cut the crossmember? What are you doing for the trackbar?
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
  2. #17
    SAS's on TTB fords are prolly the easiest SAS's to do. for removing the old front end, all that is needed is to grid off some rivets. unlike other front ends that require torching several brackets. for instillation, all you have to do is weld on a trac bar mount and move the radius arm mounts.
    i would say that he is using the stock 78 bronco tracbar. with enough lift is it nessacary to shave the engine crossmember?
    Steven W
    02 Dodge 2500
  3. #18
    BigRedFord04
    I'm using a superlift adjustable trac-bar...$125 thru O'Reilly. and yes, i did have to cut both halves of the engine cross member significantly, 4" or more, and remove the factory power steering cooler. I have pics of that too in the roll needing to be finished...i'm doin' what i can. oh, and to take the TTB off only took 5 bolts on each side once the wheels were off (radius arm, coil keeper, shock, pivot bolt, and steering linkage @ the knuckle). i think that part took all of 30mins.
  4. #19
    San Antonio
    Austin
    Congrats Austin
  5. #20
    Brazos County
    Hey Austin - looked for you on Sunday at 360 to no avail. Get those pics done i want to see what it looks like. My TTB pisses me off more everyday.
    Seth
  6. #21
    BigRedFord04
    wanna buy spare parts?
  7. #22
    bigFAWKINranger
    Seth
    hey seth, dan reed myself and a couple others were there... what time did you go?
  8. #23
    Krawler68
    I wanna see finished pics...not you all hot and greasy...oh nevermind...i want more revealing hot and greasy shots...
  9. #24
    BigRedFord04
    check out those cans!!
    *Caption* TTB getting taken to its new home...the yard
  10. #25
    Brazos County
    i don't even know if spare parts would help mine - i need some major frame reinforcement around my steering box...again. >:-l
  11. #26
    Brazos County
    oh yeah btw i was out there around 5 til 7 maybe.
  12. #27
    H-TOWN
    good job Austin! I am glad to see that someone in the club has some balls.
    Just cut the crap off people! Follow Austin's lead, it's not that bad, I think I have done at least 4 swaps already.
    Scott, FTAC '99
    '89 "CJ-7" - Her trail rig
    scott.schubring@williams.com
  13. #28
    bigFAWKINranger
    well in my defense- my sas was postponed not due to lack of BALLS, but lack of FUNDS after my SAS credit card paid for a new tranny...
    but i am damn near ready to do it... just need a few little things now and i'll have it done...
  14. #29
    San Antonio
    SAS
    Maybe the reason I didn't get the swap done was because I didn't have a "SAS credit card". I refuse to be in debt for the swap. How many of you can say you did the swap witout using a credit card or long for any of it?
  15. #30
    VW Ninja Jackasic's Avatar
    Jackasicstan
    proudy paid cash
    then again mine came with one
    Looks good Austin, should be fun out at Llano.
